20 Most Recent Compaq Microportable 1400 Multimedia Projector Questions & Answers
Hi gambill32
If the VGA is a output you could get a converter that takes VGA to Component ( RGB ) and hook up the 3 x component RCA's to the TV 's component in.
This converter can be found at most good PC and AV shops.
Good luck and thanks for using Fixya.
P.S. If you need any further guidance , just send me a request.
Compaq... | Answered on May 13, 2008
Go to Control Panel look and see what printer or printers are connected to your PC.
Then I would try to reinstall my new printer.
Compaq Office... | Answered on May 17, 2017
You need the Windows XP driver for The Compaq A-1000 printer. Which is necessary as well as up so 15245 for all printer features.
Compaq Office... | Answered on May 03, 2017
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Compaq Office... | Answered on Nov 06, 2016
Try putting flyers in letter boxes, pet shops and shopping centres.
Compaq Office... | Answered on Oct 23, 2012
you need to go to Hp website for printer software but specifically for your operation system type and install the drivers. HP has this.
Compaq Office... | Answered on Dec 28, 2011
Just type web cam in your search box. and type like this... web cam ...... press enter pheireith244_3.jpg
Compaq Office... | Answered on Sep 01, 2011
Welcome to FixYa!
This maybe a problem with the software inside the tower. You will need to check some settings as well. please follow instruction below.
1. Click on START
2. Type REGEDIT on the search bar on START Menu on the Run Box
3. Expand HKEY_LOCAL_MACHINE
4. Expand SYSTEM
5. Expand CurrentControlSet
6. Expand Control
7. Expand Class
8. Click {4D36E965-E325-11CE-BFC1-08002BE10318}
9. Look for the Upper Filters / right click on it / click on Delete
10. Look for the Lower Filters / right click on it / click on Delete
11. Restart PC
12. Try you CD / DVD ROM
If nothing happens, click on this link then click on RUN and follow the steps, then restart computer and try to run a disc again, if still nothing happens, theres a possibility that the problem is with the hardware side or the media player that you are you using...
Hope this will help...Thank you for using Fixya...
Compaq Office... | Answered on Jun 05, 2011
Try reseating the ink cartridge. Maybe, the cartridge is not seated properly.
Here are the simple steps:
1. Lift the control panel by holding the panel along the top edge.
2. Pull the control panel forward.
3. Lift the ink cartridge access door. for better access, stow the document input tray away. the carriage will move to the center.
4. Then, try reseating the cartridge. Hold the ink cartridge by the black
areas or colored top only.
Good luck,
Ryan
Compaq Office... | Answered on May 24, 2011
Normaly under My Computer - Scanners and Cameras
Compaq Office... | Answered on Feb 14, 2011
Hi there! Follow this link to download the drivers for HP officejet 4355. Make sure you select the correct operating system when downloading the driver:
http://www.siliconguide.com/drivers/device/553/
Kind regards Martin
Compaq Office... | Answered on Feb 07, 2011
Compaq Microportable 1400 Multimedia Projector Logo
2 questions posted
Top Compaq Office Equipment & Supplies Experts
Thomas F. Schneider
Damen Wong
Damen Wong
Alun Cox
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Compaq Office Equipment & Supplies
Most Popular Question
compaq projector
  • Office Equipment & Supplies
