20 Most Recent ASUS NVIDIA GeForce 9500GT, (512 MB) PCI Express Video Card Questions & Answers
Ge force 9500gt, 512mb, ddr2 compatible with asus a7n8x deluxe
The ASUS A7N8X only supports AGP8X, the 9500GT is PCI Express. There is no way the 9500GT will work with this board.
12/15/2011 9:54:10 AM • ASUS NVIDIA... • Answered on Dec 15, 2011
Nvidia GT218 40nm. Where can I get a driver?
Download Drivers Here is a link to download Nvidia drivers
2/7/2016 2:02:36 AM • ASUS GeForce... • Answered on Feb 07, 2016
2answers
Graphics card Information, Asus s/n :5BC0AC734373
There should be a model number on the board somewhere. A search of the model number would be better. You may have to remove a fan to see the chipset, then go to the Asus website and look up the video cards that use the same chipset. Graphics Cards ASUS
2/20/2015 8:07:51 PM • ASUS GeForce... • Answered on Feb 20, 2015
DRVER CRASHED LESS THAN A WEEK AFTER INTALLING LATEST VERSION OF DRIVERS [NVADIA GEFORCE 8500GT] 512MB
Did you try to play games for a long time, with the stock cooler. i'm amazed about all the gammer which are still using stockcooling and the teperature stays warm for 5 hours. And if i say they need to watercool it, just like you cpu and memory, because high temps degrease 1. the lifespan of your gear ( especially mb with cheap capacitors) enemoursly, but they overclock the graphiccard at the same time , while the effectivity decreases , caused by too warm components, they want also higher ratings from the card by overclocking. That's why i never by second hand cards or mb's or cpu's. Does the card still work; if not, does it smell burning? and did it broke, while gaming?????
7/22/2014 10:00:41 PM • ASUS GeForce... • Answered on Jul 22, 2014
What gpu should i use on a new medion from aldi
What operating system are you running on the PC? Do you have the appropriatre drivers? Have you loaded them?
3/10/2014 11:40:33 AM • ASUS GeForce... • Answered on Mar 10, 2014
0answers
Horizontal streaking and color distortion
Check very well that the connection of the connectors is right: push the videocard lightly onto the motherboard, with a little wriggling. Maybe remove and clean connectors with alcohol and then reput it in. Also check the powerline connector very well. if this is of no help, I am afraid it is broken.
2/7/2014 9:27:12 PM • ASUS GeForce... • Answered on Feb 07, 2014
My VGA has been corrupted. How can I fix it?
Hi , I suggest to check for any thermal issues including condition of the video card fan / heat sinks ie dust , If supported you can run a LINUX disk like Ubuntu in live / try mode If video works ok , then most likely a Windows environment incl hardware conflict or virus / driver corruption issue , but if not then most likely a video card hardware issue like bad card cooling fan or excessive dust - thermal shedding issue or card bios/chipset fault If a likely software issue then uninstall and then reinstall the video card Consult ASUS or Nvidia support The procedure is something like this Onboard video support ? yes uninstall the video card driver and any video vendor configuration applets Uninstall video card in device manager if still present. Shut down and remove mains power cable remove the hardware video card , (using anti static electricity procedures) Attach onboard video to display Power up and enter and configure BIOS setup if required, ie 1st seek onboard video Bootup to Windows Install the onboard video device using Windows plug&play default driver executed during booting Restart Confirm working ok Update the chipset driver (inf) if applicable, restart Shutdown Reinstall the hardware video card Attach to display Reconfig BIOS setup if required Start to install default driver Install video driver / update from card default using a known good driver whose setup file has been previously downloaded restart and test Hope this helps
12/7/2013 10:31:37 AM • ASUS GeForce... • Answered on Dec 07, 2013
Asus gpu wont work with Medion Akoya pc
When you say "gpu wont work" what do you mean? What does it do or not do? Thanks
11/20/2013 11:28:06 AM • ASUS GeForce... • Answered on Nov 20, 2013
Pnpdrivernotfound windows 7 x64
Try the ASUS website for the driver. If that is what you are looking for. (It even tells you in the information you provided.)
9/20/2013 2:31:47 AM • ASUS GeForce... • Answered on Sep 20, 2013
Can't find geforce 8900 driver
Follow this link and click on the "Graphic Drivers" buttonhttp://www.nvidia.com/Download/index.aspx?lang=en-us
2/27/2013 7:39:41 PM • ASUS GeForce... • Answered on Feb 27, 2013
Nvdia 9400 gt on P5GD1-TML/S
Yes, your mainboard supports up to 2GB of DDR memory. That does not change if you add a graphic card. Windows XP 32 bit can actually address up to 4 GB of total memory including CD, hard drives, and video cache. Note: Your mainboard only supports up to 2 GB, but newer boards can support much more memory, up to 16GB of RAM.If you could install 4 GB of RAM in your machine, it would still work, but windows would only address as much RAM as it can use; the rest would go unused, so it would probably show up as 3.5 GB of RAM then.
1/6/2012 4:23:19 AM • ASUS GeForce... • Answered on Jan 06, 2012
ASUS P4S800-MX Error message STOP: 0xc00007b error during Windows XP installaton
Probably corrupt DLL files, maybe due to incorrect decompression or dirty CD.
1/22/2024 7:50:40 PM • ASUS Computers &... • Answered on Jan 22, 2024
My 4-year-old Chromebook laptop is getting slower. Is there a way to improve the performance of the Chromebook?
Run CCleaner
Download CCleaner
Download CCleaner for FREE. Clean your PC of temporary ... Run MalwareBytes Anti-Malware
Malwarebytes: Cyber Security Software and Anti-Malware
Malwarebytes https://www.malwarebytes.com Malwarebytes gives you protection you can trust, alerting you instantly when we see your information has been stolen. Our live agents can even help you restore ... Both have free versions, but I have bought both. Then go to Startup and remove TSRs (terminate and stay resident programs) that have been added by new programs. ..
1/12/2024 11:24:51 PM • ASUS Computers &... • Answered on Jan 12, 2024
ASUS NVIDIA GeForce 9500GT, (512 MB) PCI Express Video Card Logo
2 questions posted
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
GeForce ASUS
  • GeForce ASUS
Most Popular Question
ge force 9500gt 512mb ddr2 compatible
  • Computers & Internet
