20 Most Recent Compaq Microportable 2810 Multimedia Projector Questions & Answers
3answers
Projector overheating and turns off after 20 mins
I have a HP VP6111 projector that works fine on a table top but overheats ( overheating ) when turned upside down and hung from my ceiling. My solution...I went to Circuit City and bought two 80mm computer fans. I also purchased a 12V power supply from Radio Shack. I put one fan on front of my projector and the other on the back of the projector and wired them into the 12V power supply. I mounted both fans with velcro. The front fan pushes air and the rear fan pulls air. The projector now runs fine without shutting off. The fans are 12V and push 34 cubic feet per minute of air. I am very happy with this solution.
2/19/2018 6:37:41 PM • Compaq... • Answered on Feb 19, 2018
2answers
Infocus IN1 Gaming Projector
Hi, I just bought the same projector Infocus IN1 and after just 15 minutes of use it turned off due to overheating. It seems that the lamp is very ineffecient and produces too much heat. The ambient temperature in the room is only 16 deg. celcius.
The solution I came up with is to have a standing fan blowing air directly on the back of the projector from less than a foot away. The standing fan which we usually use here in summer was enough to keep the projector cool. The infocus IN1 did not switch off for the next 2 hours (the entire length of the movie), until i turned it off myself. I am not sure how this system will fare in summer when the room temperature reaches 30 deg. celcius.
3/14/2009 1:04:56 AM • Compaq... • Answered on Mar 14, 2009
Printer
Go to Control Panel look and see what printer or printers are connected to your PC. Then I would try to reinstall my new printer.
5/17/2017 4:08:06 PM • Compaq Office... • Answered on May 17, 2017
0answers
I have win.xp operating sys. trying to connect
You need the Windows XP driver for The Compaq A-1000 printer. Which is necessary as well as up so 15245 for all printer features.
5/3/2017 1:16:46 PM • Compaq Office... • Answered on May 03, 2017
Looking for service manual compaq PM1200 projector with no power
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
11/6/2016 11:46:19 AM • Compaq Office... • Answered on Nov 06, 2016
0answers
0answers
0answers
Where can i get free advertising for petsitting in clarksville tn
Try putting flyers in letter boxes, pet shops and shopping centres.
10/23/2012 6:18:01 AM • Compaq Office... • Answered on Oct 23, 2012
I bought a HP photosmart C7200 series printer in2008. Now my computer operation system is window 7, but the printer software doesn't supports this operation system. How to resolve the problem?
you need to go to Hp website for printer software but specifically for your operation system type and install the drivers. HP has this.
12/28/2011 9:27:45 PM • Compaq Office... • Answered on Dec 28, 2011
I dont know how to
Just type web cam in your search box. and type like this... web cam ...... press enter pheireith244_3.jpg
9/1/2011 4:42:41 PM • Compaq Office... • Answered on Sep 01, 2011
0answers
Tower wont read any disc
Welcome to FixYa!
This maybe a problem with the software inside the tower. You will need to check some settings as well. please follow instruction below.
1. Click on START
2. Type REGEDIT on the search bar on START Menu on the Run Box
3. Expand HKEY_LOCAL_MACHINE
4. Expand SYSTEM
5. Expand CurrentControlSet
6. Expand Control
7. Expand Class
8. Click {4D36E965-E325-11CE-BFC1-08002BE10318}
9. Look for the Upper Filters / right click on it / click on Delete
10. Look for the Lower Filters / right click on it / click on Delete
11. Restart PC
12. Try you CD / DVD ROM
If nothing happens, click on this link then click on RUN and follow the steps, then restart computer and try to run a disc again, if still nothing happens, theres a possibility that the problem is with the hardware side or the media player that you are you using...
Hope this will help...Thank you for using Fixya...
6/5/2011 12:49:48 AM • Compaq Office... • Answered on Jun 05, 2011
I installed new ink in
Try reseating the ink cartridge. Maybe, the cartridge is not seated properly.
Here are the simple steps:
1. Lift the control panel by holding the panel along the top edge.
2. Pull the control panel forward.
3. Lift the ink cartridge access door. for better access, stow the document input tray away. the carriage will move to the center.
4. Then, try reseating the cartridge. Hold the ink cartridge by the black
areas or colored top only.
Good luck,
Ryan
5/24/2011 5:11:00 AM • Compaq Office... • Answered on May 24, 2011
How do u turn camera
Normaly under My Computer - Scanners and Cameras
2/14/2011 10:31:28 AM • Compaq Office... • Answered on Feb 14, 2011
1 want the driver of
Hi there! Follow this link to download the drivers for HP officejet 4355. Make sure you select the correct operating system when downloading the driver:
http://www.siliconguide.com/drivers/device/553/
Kind regards Martin
2/7/2011 8:31:15 PM • Compaq Office... • Answered on Feb 07, 2011
Compaq Microportable 2810 Multimedia Projector Logo
2 questions posted
Top Compaq Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Compaq Office Equipment & Supplies
Most Popular Question
projector overheating turns off after 20
  • Office Equipment & Supplies
