20 Most Recent Samsung E2222 Chat 222 Dual Sim Mobile Phone Questions & Answers
Its restarting with it self when i doing master
problem might be with battery do u use the same charger which has come with the phone, put your phone in charging and do master reset
11/4/2013 9:43:40 AM • Samsung E2222... • Answered on Nov 04, 2013
Now i am do a master reset buttmy mobile is not
update the phone system
9/29/2013 3:14:04 PM • Samsung E2222... • Answered on Sep 29, 2013
My samsung mobile is when i am insert a memory
Pl back up your datas and once agin reinstall the softwares
9/26/2013 7:55:54 AM • Samsung E2222... • Answered on Sep 26, 2013
Samsung iDCS 18D Digital Telephone shows "ask them to hold" on the display. What does this mean and how can I get rid of it?
Here is the manual While the manual is on the screen press CTRL+F, type 'hold' in the box and press Enter. It has many Hold features http://www.hardwiretelecom.com/pdfs/Samsung%20iDCS_User_Guide.pdf ..
6/13/2023 4:33:33 PM • Samsung Lands... • Answered on Jun 13, 2023
Samsung IDCS 28D system: How do I unblock access to outside lines? No lights show on the dead lines. Handset works in other offices.
It is possible that the outside lines have been blocked in the programming of the Samsung IDCS 28D system. You can try the following steps to unblock the outside lines:
  1. On a phone that is working, press the TRANSFER button and dial 200.
  2. Enter your system password. If you don't know your system password, you may need to contact your phone system administrator or service provider.
  3. Press 713 for "Line Block Release".
  4. Press the button for the line that is blocked (in your case, all 4 lines).
  5. The display should show "RELEASE OK" for each line that is unblocked.
  6. Hang up the phone.
If this doesn't work, it is possible that the phone system may need further troubleshooting or programming by a technician.
2/28/2023 5:53:32 AM • Samsung Lands... • Answered on Feb 28, 2023
Samsung IDCS 28D system Outside lines blocked by accident. How can I undo it please?
To unblock the outside lines on a Samsung IDCS 28D system, you can follow these steps:
  1. Press the "Transfer" button on your phone.
  2. Dial "741".
  3. Press the "Transfer" button again.
This should unblock the outside lines on your system. If this does not work, you can try resetting the system by unplugging it for a few minutes and then plugging it back in. If the issue persists, you may need to contact a professional to troubleshoot the system further.
2/28/2023 5:53:06 AM • Samsung Lands... • Answered on Feb 28, 2023
Samsung iDCS 28D Calls not going to VM after canceling a forward on no answer
It's possible that when you cleared the forward on no answer, the voicemail setting on your Samsung iDCS 28D was not properly restored. Here are some troubleshooting steps you can try:
  1. Check your voicemail settings: Dial 604 and press the "Speaker" button. Enter your extension number and press the "Speaker" button again. The system should confirm that you have entered the correct extension number. If it does not accept your extension, try dialing from a different phone to make sure that your extension is still active.
  2. Verify your call routing: Dial 601 and press the "Speaker" button. This will show you the current call routing for your extension. Verify that "No Answer" is set to go to your voicemail box. If it is not, you can change it by pressing the "Speaker" button and entering the appropriate code for voicemail (usually "72").
  3. Restart the phone system: If the above steps do not work, try restarting the phone system. You can do this by unplugging the power cable from the phone system for a few seconds and then plugging it back in.
If none of these steps resolve the issue, you may need to contact your phone system administrator or IT support for further assistance.
2/28/2023 5:19:26 AM • Samsung Lands... • Answered on Feb 28, 2023
I have a Samsung OfficeServ DS-5038S. An extension light keeps flashing red. When i dial the extension it gives the engaged tone but there is no one using the phone. What could it be?
If an extension light on your Samsung OfficeServ DS-5038S phone is flashing red and dialing the extension gives an engaged tone even though no one is using the phone, it's possible that the extension is stuck in a busy or engaged state. Here are some steps you can try to resolve the issue:
  1. Check the extension: Go to the extension in question and make sure the handset is on the hook and that there are no other phones or devices using the line.
  2. Restart the phone: Try restarting the phone by unplugging it from the power source for a few seconds, then plugging it back in.
  3. Check the programming: It's possible that there is an issue with the phone's programming. Check the phone's user manual or contact your phone system administrator to ensure that the extension is programmed correctly.
  4. Check the phone system: If the issue persists, it may be necessary to check the phone system itself for any issues that could be causing the extension to appear busy or engaged.
  5. Replace the phone: If none of the above steps resolve the issue, it's possible that there is a hardware issue with the phone itself. Consider replacing the phone or contacting a qualified technician for further assistance.
It's important to note that some phone systems are configured to automatically put extensions into a busy or engaged state after a certain period of time to prevent unauthorized access. If this is the case, contact your phone system administrator to adjust the settings accordingly.
2/26/2023 10:10:57 AM • Samsung Lands... • Answered on Feb 26, 2023
In our office we have Samsung LCD 12B phones. We had a power outage 2 days ago and now only one phone will ring. We are also unable to make calls outbound but there is a dial tone.
Hi, for the phone that is malfunction, you'll need to setup as if it was brand new. The outage probably caused it to lose most of it's memory from the initial setup. To avoid having any difficulties, please reference the manual as you're going through these steps. Thank you.
6/3/2022 7:25:00 PM • Samsung Lands... • Answered on Jun 03, 2022
How do you change the outbound caller ID on a Samsung IDCS 28D?
Not for outbound, only spammers and scammers do that. It is set by your telcom. Incoming mention in the manual https://www.manualslib.com/manual/949871/Samsung-Idcs-28d.html?page=31 ..
5/16/2022 11:00:40 PM • Samsung Lands... • Answered on May 16, 2022
Why when I push my voicemail button, why do all the other phones ring?
This appears to be the phone, Samsung iDCS-28 https://www.pcliquidations.com/p1489-samsung-idcs-28d-falcon This appears to be the Samsung 7100 https://www.samsung.com/us/televisions-home-theater/tvs/uhd-tvs/43--class-ru7100-smart-4k-uhd-tv--2019--un43ru7100fxza/ You have a phone connected to a television? Contact Samsung Support Direct. The phone doesn't have voicemail built in, so you are dialling your telco to get them. What you are pressing is a signal to ring the other phones.
11/30/2021 10:13:52 PM • Samsung Lands... • Answered on Nov 30, 2021
Samsung IDCS 28D says "Self test start ! # to next test" and constantly beeps a tone.
Must reset all extensions with individual extension numbers after a power outage. Just the same as starting the phone out of the box. Thanx.
6/21/2021 6:45:26 AM • Samsung Lands... • Answered on Jun 21, 2021
I have Samsung office serv 7200 . My DND is not working with external calls
SORRY BUT WE ARE NOT YOUR PHONE SERVICE PROVIDER
4/21/2021 1:52:52 PM • Samsung Lands... • Answered on Apr 21, 2021
I HAVE A SAMSUNG IDCS 28 D PHONE SYSTEM. EVERYTHING LOOKS NORMAL. BUT, I PICK UP THE PHONE, THERE IS A DIAL TONE. BUT IT WON'T LET ME MAKE A CALL. WHEN I DIAL THE NUMBERS IT DOES NOTHING
The Spaminator Feb 26, 2021 Hi Julie Dyreng, check the dialing mode is on tone rather than dec or pulse
4/20/2021 1:06:49 PM • Samsung Lands... • Answered on Apr 20, 2021
7answers
I need a sim network unlock pin for my pantech crossover?
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
3/21/2021 12:49:35 AM • Samsung Lands... • Answered on Mar 21, 2021
7answers
Recover pictures from Samsung Smart phone?
Definitely Yes! First of all, you should stop saving any new files to your Samsung smart phone (or SD card) or taking new pictures.
Then find some photo recovery software from this site Best Computer Software, which are able to recover deleted or formatted photos from cell phone, digital camera, memory card and SD card etc.
Digital Photo Recovery for Windows
Digital Photo Recovery for Mac OS X
Here are the steps:
Step 1: Download and install the Digital Photo Recovery Software.
Step 2: Connect your Samsung smart phone (or SD card, memory card etc) to your PC or Mac.
Step 3: Scan the source drive where your lost pictures located.
Step 4: Recover the lost pictures and save them to another drive instead of the source drive.
2/25/2021 4:18:49 AM • Samsung Lands... • Answered on Feb 25, 2021
Model idcs 28d. Why does it indicate 'message storage unit is full'?
Look for a 'message delete' button and try pushing it several times to clear storage.
1/25/2021 11:47:23 PM • Samsung Lands... • Answered on Jan 25, 2021
3answers
Samsung A847 unlock code
You may purchase the SAMSUNG A847 unlock code from a SAMSUNG UNLOCK CODE provider. Their codes are accurate and safe backed by their money back guarantee.
9/8/2020 7:35:15 AM • Samsung Lands... • Answered on Sep 08, 2020
8answers
Free unlock code for Samsung gt-e 1170 T mobile
you will have to perform a full reset of the phone. Keep in mind that the reset will delete everything in the mobile phone, like images, personal files..etc. Just Dial, without SIM in the phone, one of this codes bellow:
*2767*2878#
OR
*2767*3855#
6/7/2020 1:25:52 PM • Samsung Lands... • Answered on Jun 07, 2020
Samsung E2222 Chat 222 Dual Sim Mobile Phone Logo
6 questions posted
Top Samsung Lands Phones Experts
Ngoro
john h
ADMIN Andrew
ADMIN Andrew
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Lands Phones
Most Popular Question
its restarting self when doing master
  • Lands Phones
