20 Most Recent
The Nesco 4808-25PR Stainless Steel 18 Quart Porcelain Cookwell Roaster Questions & Answers
Where can I find the 'production cycle' that includes minutes for beating mixture to letting rise, baking, etc
All questions need 'make model (what is is)' as first 3 words.
This sounds like a bread maker? I bake bread every 2 weeks, but using traditional methods.
Mix ingredients to shaggy dough, leave to Autolyse for 30 minutes.
Knead for 10 minutes.
Prove 1 hour.
Knead 10 minutes.
Form and Prove for 1 hour.
Bake 35 minutes.
For your machine, Google
make model manual
Most are online, or click Comment under my answer and I will try and find it.
Keep Your Fridge Clean for Maximum Freshness
A clean refrigerator helps keep your food fresher for longer. Here are some tips to keep your fridge in top shape:
- Clean out leftovers once a week - old food can get moldy and contaminate other items. Designate a day each week to check for leftovers or expired items that need tossing.
- Wipe up spills immediately - quick clean-up keeps messes from getting out of hand. Keep a rag handy to wipe up any drips or leaks.
- Wash shelves every 1-2 months - take everything out and wash the interior. This prevents buildup of bacteria that could transfer to food. Use a baking soda solution for extra disinfecting power.
- Check door seals annually - faulty seals allow cold air to escape, meaning your fridge works harder. Make sure seals are intact with no cracks or gaps.
- Replace air filters as needed - clean filters maximize efficiency. Most fridges have easily removable mesh screens that can be rinsed or vacuumed when visibly dusty.
Following these fridge cleaning tips helps ensure optimum temperature regulation and food storage. A few minutes of regular maintenance goes a long way towards refrigerator freshness! Implement one new tip each week until you've got an appliance that keeps food colder for even longer.
https://www.dominatekitchen.com/
Bread recipes for model 109914 ?
All will be found in your user manual or onlune on their web site.
Similar to all other bread making machines.
600g Strong flour, 2Tbs fast acting yeast, 435ml wearm water, pinch of salt, 20g butter and 1tsp sugar.
Use 450ml water for wholemeal.
ART712SB feet rubber pads
Rubber feet pads in the ART712SB model can be purchased online from retailers such as Amazon, eBay, and AliExpress. They can also be purchased from hardware stores such as Home Depot, Lowes, and Ace Hardware.
My Swan Teasmade's light will not go on, so the kettle won't boil. I've tried moving the water pot around inside the holder, but nothing works.
If the light on your Swan Teasmade is not turning on and the kettle isn't boiling, there could be several reasons for this issue. Here are some troubleshooting steps you can try to identify and potentially fix the problem:
- Check the Power Source:
- Ensure that the Teasmade is properly plugged into a working power outlet. Try using a different outlet to rule out power supply issues.
- Inspect the Power Cord:
- Examine the power cord for any visible damage or fraying. If you find any issues, it's important to replace the cord with a new one.
- Check the Fuse:
- Teasmades usually have a fuse inside. Check if the fuse has blown. If it has, replace it with a fuse of the same rating.
- Water Level Sensor:
- There might be an issue with the water level sensor. If the Teasmade doesn't detect water, it might not turn on. Clean the sensor area and ensure there are no blockages.
- Heating Element:
- The heating element might be faulty. If the Teasmade is under warranty, contact the manufacturer for repairs or replacement. If not, you might need to take it to a professional repair service.
- Thermostat Issues:
- The thermostat that controls the boiling temperature might be malfunctioning. This would require professional repair or replacement.
- Manufacturer Support:
- If your Teasmade is still under warranty, it's best to contact the manufacturer's customer support for guidance and possible repairs. They might have specific troubleshooting steps tailored to your device.
How do I adjust the roller width of my pasta maker as it seems to be 'locked' @ #6
If the roller width of your pasta maker seems to be locked at a specific setting, like #6, and you're unable to adjust it, here are some steps you can try to troubleshoot and potentially fix the issue:
- Inspect for Obstructions: Check for any debris, pasta dough residue, or foreign objects that might be blocking the mechanism responsible for adjusting the roller width. Clean the machine thoroughly and remove any obstacles that could be causing the locking.
- Lubrication: Sometimes, the adjustment mechanism can become stiff due to lack of lubrication. Apply a small amount of food-grade lubricant or vegetable oil to the moving parts and joints, and work the adjustment knob back and forth to help loosen it up.
- Gently Apply Pressure: While the machine is off and unplugged, try gently applying pressure to the adjustment knob while attempting to turn it. This might help release any stuck parts or overcome resistance.
- Wiggle and Jiggle: Gently wiggle and jiggle the adjustment knob while attempting to turn it. Sometimes, this slight movement can dislodge any stuck components and allow for proper adjustment.
- Use a Tool: If the knob is particularly stubborn, you can use a pair of pliers or a wrench (wrapped in a cloth to prevent scratching) to help turn the knob while applying gentle pressure. Be cautious not to apply too much force to avoid damaging the machine.
- Consult the Manual: If you still have the manual that came with the pasta maker, refer to it for troubleshooting tips specific to your model. There might be manufacturer-recommended solutions for this issue.
- Contact Customer Support: If none of the above steps work, it might be best to contact the manufacturer's customer support or service center for assistance. They can provide you with more detailed guidance or arrange for repairs if necessary.
Remember, always exercise caution when working with kitchen appliances, and avoid using excessive force that could potentially damage the machine further. If you're not comfortable attempting these steps yourself, it's better to seek professional assistance to avoid causing further damage to your pasta maker.
