20 Most Recent
Metrologic Instruments Voyager MS9520 Handheld Questions & Answers
Voyager 5929 doesn't work with Vista
The problem isn't your scanner or Vista, it's your adapter. Power requirements and speed of data require special adapters. One I always recommend is Scan Technology's part # STI-PS2-USB. I've tested it with all Metrologic scanners and it hasn't failed yet.
Incorrect Reading
Try experimenting with the different inter-scan code delays. You can find the programming barcodes in your manual.
I need a driver for MK6520-31A08
OK my friend... after all your hard work I recommend go to this link and start reading! Pick your the program YOU think will help you most...
Now BEFORE you install ANYTHING be SURE you have *everything* important to you backed up!
These are ALL supposed to be "The BEST" FREE programs as of 12/1/17 so here you go...
11 Free Programs That Will Help Update Drivers in Windows
ALLOW the
SOFTWARE to do your hunting. Sometimes they give you IMPORTANT INFORMATION about your missing drivers! Others give you specific LINKS to them.
And others may CLAIM they FOUND
the very drivers you need and
YOU can have them too ~ for $50... no fun.
A final note... Be sure the drivers you select and install are compatible with your XP Operating System (
32-Bit I suspect).
Best of luck fishing!
Anthony
