20 Most Recent
Polaroid I531 Battery (Equivalent) Questions & Answers
Polaroid rechargeable batteries in duracell charger
The problem isn't the brand of batteries Vs. charger; the problem is the electrical rating of the charger Vs. the charging specifications for the batteries. First make sure that the batteries are the correct type; i.e., nicad, lithium ion, etc. Do not try to recharge alkaline batteries. Your batteries have a mili-amp hour rating either shown on the battery or in the manufacturers specifications that are available on line. Each battery type also has charging specifications. The battery charger is designed to provide a specified charging voltage and current to the batteries and those specifications must match the battery's design. Using the incorrect charging voltage and current can cause the batteries to overheat and even explode.
Green light flashing on Polaroid iE 6035
The green light flashing on your Polaroid iE 6035 camera typically indicates that the camera is in standby mode or that it is charging. If the camera is not charging, it could be a sign of a problem with the battery or charging mechanism. If the green light continues to flash even after charging, it may be necessary to take the camera to a professional for repair or to have the battery replaced. Before seeking professional help, you can also try resetting the camera or removing and reinserting the battery to see if that resolves the issue.
