20 Most Recent Heath Zenith All Metal Motion Sensor Light Control, 270;, Detection Zone, Lifetime Warranty, Bronze Questions & Answers
0answers
I have this light for 2 years with no problems at
  1. Locate the sensor on the motion detector. The most common problem with a motion detector is a sensor that is obstructed or dirty. Remove any dirt, grime or anything else that may be blocking the view of the sensor. If you need to actually touch the sensor itself to clean it, use a soft cloth or cotton swabs.
  2. Determine if the motion detector has electricity running through it properly. Connect an electrical meter to the wires from the sensor itself. If electricity is indeed running to the sensor, you likely have a broken senor. If there is no electricity making it to the sensor, your motion detector has an electrical short. In the case of an electrical short, you will need the help of a professional electrician to fix it.
  3. Visit a hardware or supply store to buy a replacement sensor
Thanks for understanding.
11/17/2011 1:26:16 AM • Heath Zenith All... • Answered on Nov 17, 2011
The manual says wire black
Depending on where box is and who wired it the red wire very well may be switched from inside. If you want to use the dusk on and off and sensor exclusively, in other words, you don't want it switched, cap off the red wire and don't use it. If you would like it switched, see if you can find a switch that will operate the red wire, probably somewhere around the nearest doorway out, or if you have a switch that you could never figure out what it was for.
4/30/2011 11:05:11 PM • Heath Zenith All... • Answered on Apr 30, 2011
Can this light be set to only come on from dusk to
Yes,this light system is a motion sensor security light.Just turn the light switch on.When the sun goes completely down,somebodies or anamials go by the sensor covering area the light will go on.The sun rise the light will go off,will not go on.
11/24/2010 11:38:59 PM • Heath Zenith All... • Answered on Nov 24, 2010
Where can i find Heath zenith SL-6273 manual or how do i make the product play mp3
Most Heath Zenith product manuals are available here: https://www.heath-zenith.com/support/owners-manuals . Searching for the SL-6273 found two versions of the wireless MP3 door chime. The direct link to the manual for the SL-6273-00 is https://www.heath-zenith.com/system/spree/documents/attachments/000/000/839/original/205371-02A.pdf?1436551434 . Put the batteries in the door chime. To transfer an MP3 to the door chime, connect it to a computer with a USB cable. Open the folder to view files and drag the new (short, <= 20 seconds long) tune into the folder. Eject the door chime (like any USB hard drive) and remove the USB cable from the door chime. Next press the Tune button to cycle through the tunes on the door chime for the front door chime. Stop when the desired tune is played. That will be played any time the front chime is pressed. If you add the jumper to pin 8, the door chime will ding as that is the rear rear door sound. For the front door, make sure that the switches (1-7) on the push button match those for the door chime. I hope this helps. Cindy Wells
6/2/2017 10:50:34 PM • Heath Zenith... • Answered on Jun 02, 2017
0answers
What are some common types of sensors and detectors used in security systems, and how do they function?
Nice question. Do you have a specific concern, or an area to protect? I am an expert by experience.
The Various Types of sensors used in the Security Alarm ...
ResearchGate https://www.researchgate.net > publication > 34047974... Apr 7, 2020 - Microwave sensor (2) Vibration Sensors: Vibration sensors are sensors that are used for displaying, measuring, and evaluating linear velocity, ... ..
4/13/2024 11:02:25 PM • Home Security • Answered on Apr 13, 2024
Heath Zenith All Metal Motion Sensor Light Control, 270;, Detection Zone, Lifetime Warranty, Bronze Logo
14 questions posted
Top Heath Zenith Home Security Experts
Steve Pack
Steve Pack
Are you a Heath Zenith Home Security Expert? Answer questions, earn points and help others
View Most Popular
  • Heath Zenith Home Security
Most Popular Question
light 2 years no problems
  • Home Security
