20 Most Recent
Callaway Golf 2002 Callaway Big Bertha 6 Iron Rch 75 Light Excellent Questions & Answers
My Golf Logix App isn't working on my iPhone 14 Pro Max.
Question edited for clarity.
Question moved from Cars and Trucks category.
It may have been corrupted update. Remove the App, reboot the phone and redownload the App. If that doesn't work, contact Golf Logix direct.
GolfLogix Home - GolfLogix - Putt Break Maps and GPS ...
GolfLogix
https://www.golflogix.com
The Complete Game Improvement App. From tee to green, GolfLogix provides the information you need to reduce strokes and play smarter.
GolfLogix is the #1 Golf App for iOS and Android. Featuring Putt ...
GolfLogix is the #1 most downloaded app for golf ...
Corporate Headquarters: GolfLogix, Inc. 4235 N ...
Mapped CoursesGolfLogix, Inc. ... Los Altos Golf & Country ..
8/15/2023 3:01:47 AM •
Golf
Answered
on Aug 15, 2023
Caddylite 11.5V2 brake assembly
not car is it. it is golf caddy , i yes be more clear
moved you from automobile cars to golf
the answer is ask the maker for help
6/4/2023 4:03:28 PM •
Golf
Answered
on Jun 04, 2023
2009 G29 Yamaha Golf Cart. Kids didn't plug in charger correctly and melted the charging port and plug. Changed both still won't charge. Charger does not work either.
If the charging port and plug have been replaced and the charger still does not work, there may be an issue with the charging circuit in the golf cart. Here are a few things you can check:
- Charging fuse: Check the charging fuse to see if it's blown. If it is, replace it with a new one of the same amperage.
- Charging relay: Check the charging relay to see if it's working properly. You can do this by using a multimeter to check the resistance across the relay contacts. If there is no resistance, the relay is bad and needs to be replaced.
- Charging receptacle: Check the charging receptacle to make sure it's getting power. Use a voltmeter to check for voltage at the charging port.
- Charging controller: The charging controller may be damaged if the charging port and plug were melted. Check the charging controller for signs of damage or overheating. If it's damaged, it will need to be replaced.
If none of these solutions work, it may be best to take the golf cart to a professional mechanic or dealer for further diagnosis and repair.
2/28/2023 4:58:11 AM •
Golf
Answered
on Feb 28, 2023
EZGO golf cart will not go
It's possible that the motor, solenoid, or wiring has become disconnected or damaged. I recommend starting with a basic inspection of all the connections, wires, and components. If all looks alright, then you may need to have the motor and solenoid tested. If there is still no luck, then you may need to replace the EZGO golf cart motor or solenoid.
1/15/2023 6:40:50 PM •
Golf
Answered
on Jan 15, 2023
