20 Most Recent Dell 2300MP Multimedia Projector Questions & Answers
The projector lamp comes on (amber color) no image
I was told by an expert that the fan should come on as soon as heat starts to come on. You should never turn a projector off with out the fan running for a while to cool the bulb down. Each projector is different but the fan has to operate on then all. There is so much heat in the bulbs that air has to keep them cool when they are operating as well have to cool gradually when they are shut down.
3/14/2017 4:02:57 PM • Dell 2300MP... • Answered on Mar 14, 2017
2answers
Dell 2400 MP DPL Projector projects a yellow tinted image.
Clean any external dust filters or air openings in the unit.If you don't want to remove the filters, you can simply use a vacuum cleaner hose to suction away the dust from the filter element--same effect anyway. The unit probably does indeed need a thorough cleaning.
The yellow effect is most probably a burned BLUE polarizer filter located behind the blue LCD panel. (Color key--Purple onscreen=green lcd, baby blue onscreen=red lcd, and yellow onscreen=blue lcd). That's how you can tell which lcd has dust on it! Usually, the green lcd has the most free area around it and collects the most visible dust. (large purple specs) The polarizer filters can get burned due to excessive heat (not keeping proper ventilation). Of course, it might be the blue LCD panel which is failing prematurely due to heat build-up over time. The polarizer filter isn't that expensive if it can be replaced, however, the actual lcd panel IS.---Rick
1/16/2015 11:51:33 AM • Dell 2300MP... • Answered on Jan 16, 2015
How to download manuals free
Anonymous, Click the link below to download online manuals for your Dell Product. Dell Support http://dell.to/1rAKwPe Thank You, Dell-Jesse L Dell Social Media and Communities
7/29/2014 12:28:11 PM • Dell 2300MP... • Answered on Jul 29, 2014
I have a DELL 2300mp i heard a loud sound and it sound like the fan was making a sound i took the bulb out it looked good ,when i took the bulb out i was get small pieces of color thin glass like a le
as your description, the color wheel should be shattered now. so you have to bur a new color wheel and replace it.if you need any further help, you can freely contact me,
4/17/2014 2:30:28 PM • Dell 2300MP... • Answered on Apr 17, 2014
Looking for replacement power supply for LG PB60G
hi Sir, tell me the model or post a photos here, perhaps i can help you to find this parts, waiting for your further news
3/31/2014 5:50:51 PM • Dell 2300MP... • Answered on Mar 31, 2014
0answers
3answers
My used DEL 2300 MP doesn't seem to be
Decrease the screen resolution of your computer to the minimum possible value and check.
Probably the projector does not support the resolution of the laptop. With a lower resolution it might work.
2/28/2014 4:59:12 AM • Dell 2300MP... • Answered on Feb 28, 2014
Recognize macbook connect
You may need to check the settings of your mac book that permits you to output the signal to an external display. Also you may need to purchase a display port adapter (VGA, HDMI or DVI) that is compatible with the input connector on the projector
12/18/2013 10:47:52 PM • Dell 2300MP... • Answered on Dec 18, 2013
When i turn the projector on i hear a noise...
it's the colorwheel. the bearings are wearing out due to excessive dust and heat. it will need to be replaced. unfortunately, dell doesn't sell parts, so you'll have to send it in for repair.
8/30/2013 6:53:07 AM • Dell 2300MP... • Answered on Aug 30, 2013
2answers
No power - looks like
JUNK IT!!! ITS A COMMON PROBLEM WITH THIS MODEL EVEN DELL CANNOT FIX IT. ITS A FIRMWARE PROBLEM OR DESIGN PROBLEM THAT THEY CANNOT FIX. THEY DONT EVEN HAVE A REPLACEMENT FOR THAT. THATS WHY DELL STOP MANUFACTURING IT AND YET THEY STILL SELLING THEM.
5/25/2013 12:14:46 AM • Dell 2300MP... • Answered on May 25, 2013
I put a new lamp in it and the lamp light still, is there
Did you go into setup and tell the projector that you installed a new lamp?
10/12/2012 5:16:37 PM • Dell 2300MP... • Answered on Oct 12, 2012
3answers
No power to my dell 2300mp
The fuse is a short round maroon colored part to the left of the power plug looking at the power supply module from the direction that you would connect the cord to. it is labeled F1 and it is a 4a 250v. This is not the problem with my power supply though. I suspect one of the components under the heatsink is bad.
as you all know don't bother calling dell.
7/28/2012 8:16:42 PM • Dell 2300MP... • Answered on Jul 28, 2012
When did the 2300 mp made
perhaps, it is at 2004, but i can't be sure,its function as following: Brightness (Lumens) : 2300 ANSI Contrast (Full On/Off) : 2100:1 Variable Iris: No Audible Noise: 38.0 dB Eco-Mode: 34.0 dB Weight: 2.1 kg Size (cm) (HxWxD) : 8 x 25 x 20 Std. Lens: Focus: Manual Zoom: Manual, 1.20:1 Throw Dist (m) : calculator.gif 1.2 - 12.0 Image Size (cm) : 62 - 743 Optional Lenses: No Digital Zoom: ** Digital Keystone: Vertical Lens Shift: No Warranty: 1 Year Performance: H-Sync Range: ** V-Sync Range: ** Compatibility: HDTV: 720p, 1080i, 576i576p EDTV/480p: Yes SDTV/480i: Yes Component Video: Yes Video: Yes Digital Input: ** Computers: Yes Display: Type: DLP (1) Color Wheel Segs: ** Color Wheel Speed: ** Native: 1024x768 Pixels Maximum: 1600x1200 Pixels Aspect Ratio: 4:3 (XGA) Light Source: Type: 200W P-VIP Life: 2000 hours Eco-Mode Life: 2500 hours Quantity: 1 Speakers: 2.0 W Mono Max Power: 250W Voltage: 100V - 240V FCC Class: B Special: RS232 Port Status: Out of Production First Ship: Sep 2004 Last Ship: May 2006
2/10/2012 4:11:07 PM • Dell 2300MP... • Answered on Feb 10, 2012
2answers
Dell 2300mp projector color wheel
no there is a little difference in it. u can fix it if knows the proper settings....
there is always a setting in every thing....
11/5/2011 11:12:56 AM • Dell 2300MP... • Answered on Nov 05, 2011
We have a Dell MP2300
It should work.Check the connecting terminal.Check the connector, which goes to the RS232.Try with another wire and see if its working.Or the wire connected loose to 232 port.---- --------- Check out, keep updated thanks.Helpmech.
6/29/2011 4:52:18 PM • Dell 2300MP... • Answered on Jun 29, 2011
Dell 2300MP Multimedia Projector Logo
133 questions posted
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Dell Office Equipment & Supplies
Most Popular Question
no power looks like
  • Office Equipment & Supplies
