20 Most Recent Korg X50 X-50 Keyboard Questions & Answers
FACTORY RESET:
  1. Press the [GLOBAL] button to enter Global mode.
  2. Press the [EXIT] button.
  3. Press the [UTILITY] button
  4. Select "Load Preload Data," by using the ClickPoint [?] button, and press the [CENTER].
  5. Choose "Kind," (All)
  6. Press the [MENU/OK] button.
  7. When a dialog box will ask you, press the [MENU/OK] button
Korg X50 X-50... | Answered on Jun 09, 2016
Your best bet is to contact Korg. Here is their link-
http://www.korg.com/us/support/contact
Korg X50 X-50... | Answered on Jan 22, 2016
5VDC is absent. The 0 Ohm safe resistor is dead. Backlight is off in this case too.
Korg X50 X-50... | Answered on Oct 23, 2015
I had an old organ/keyboard repair man tell me 95% of his repairs were diodes over 10 years old. Everything else was switches, capacitors & transformers. Hope that helps.
Korg X50 X-50... | Answered on Aug 25, 2015
6. Playback
(1) Set channel 1 to play.Turn the REC/PLAY key on. Then press the channel key of track 1 (the track you just recorded) to set it to Play (key lit green).
(2) Return to the beginning of the song.Hold down the STOP key and press the REW key to return to the beginning of the song (?p.37 "2. Location").
Korg Music | Answered on Jul 12, 2019
I will assume you want to sync the two as one. I have one of these sitting in a closet. The 3200 will record 12 tracks at a time if I remember correctly. I believe the Korg will sync to Midi Time code. I just wonder if the midi implementation allows for start and stop code. Anyway, I found this information:
x2. MIDI messages used by the D3200 Note On (Note, velocity), aftertouch, pitch-bend:
The D3200 uses these messages to control effects.
Program change:
The D3200 uses these messages to switch scenes.
Control change:
The D3200 uses these messages to control mixer and
effect parameters.
MMC (MIDI Machine Control):
MMC messages can be transmitted from the D3200 to control an external MMC-compatible sequencer or recorder. MMC messages received from an external sequencer or recorder can be used to control the D3200.
MTC (MIDI Time Code):
The D3200 can transmit or receive MTC messages to
synchronize with an external sequencer or recorder.
MIDI Clock:
The D3200 can transmit MIDI Clock. It can also receive MIDI Clock if you have selected MIDI Clock for the tempo track and are recording the tempo track.
Email Korg customer service in your country for advice, or search the manual if you have it.
Korg Music | Answered on Jul 07, 2019
Korg X50 X-50 Keyboard Logo
8 questions posted
Top Korg Music Experts
Michial Gueffroy
Poul Brinchs Larsen
tmaree
tmaree
Are you a Korg Music Expert? Answer questions, earn points and help others
View Most Popular
Korg Music
  • Korg Music
Most Popular Question
gm voice not playing
  • Music
