20 Most Recent Lexicon Mx200 Reverb Delay 1u Effects Processor Questions & Answers
If unt was dropped, look for broken PC board in the vicinity of the rotary encoder. Also look at solder connections to make sure they are sound. A little contact cleaner applied to encoder through an opening so the spray gets inside will help clean contacts. If the knob itself is hard to turn, the shaft is likely bent, and there may be damage to the encoder itself.
Lexicon Mx200... | Answered on Oct 28, 2012
hello I have the same problem, I'm told that updating the firmware of the Lexicon MX200 is solved but it turns out that my pc does not recognize the device via USB to update, any solution? thank you very much
Lexicon Mx200... | Answered on Apr 08, 2012
you SHOULD be able to.
Just use Direct Sound in the host tab.
Lexicon Music | Answered on Mar 19, 2017
You need to contact the manufacturer, Fixya did not sell you the item and we do not have the activation key.
Music | Answered 2 days ago
If it is just the one note that has stopped working it is probably the contact strip.
you could check this by moving one of the contacts from a working octave to the non working octave, if it solves the problem just replace the contact strip.
report back if this solves the issue and I can point you in the right direction for the part needed.
Dan
Becketts Music
Music | Answered 3 days ago
Are you using the power supply that came with it? If not that may be the issue, or the power supply itself may be bad.
Music | Answered on Sep 15, 2019
I understand your pain - was googling for similar, and came across this post, 5 years prior. My SGC Nanyo Bass Collection has just started to play silly beggars with the pots, and a bridge fault. Nowhere online seemed to have any details of the wiring, as the problem is, as you say, the fact that all of the tone and volume pots are based on a printed circuit board. If theres a nick or short on the board, its a pig to replace, and I really wouldn't like to have to wire any pots onto it. I'm currently looking at the options of ripping out the old electrics and wiring it from scratch myself. If you're still after answers, good luck!
PS - noted that none of the previous replies are relevant to this - mostly going on about the amps or a Fender guitar??!
Music | Answered on Sep 13, 2019
Lexicon Mx200 Reverb Delay 1u Effects Processor Logo
8 questions posted
Top Lexicon Music Experts
Michial Gueffroy
Gil Shultz
tmaree
tmaree
Are you a Lexicon Music Expert? Answer questions, earn points and help others
View Most Popular
Lexicon Music
  • Lexicon Music
Most Popular Question
lexicon mx 200 preset knob frozen
  • Music
