20 Most Recent
Opticon LGE1105RHHS-000 Handheld Questions & Answers
How to download service manual for lge cdma model
This is the Opticon website:-
http://www.opticonusa.com/solutions/tech-support
The only manual they have is the Universal menu manual.
If you can't find the manual you need here, I suggest you contact their tech support guys and ask them to point you in the right direction.
4/13/2010 1:46:41 PM •
Opticon...
Answered
on Apr 13, 2010
LG phone
my lg fone mod.no.c3380s screen is reverse after 1minute when phone will switch then after continue as reverse screen
6/24/2008 6:22:18 PM •
Opticon...
Answered
on Jun 24, 2008
Won't read fonts
Please try to reset your scanner configuration, using some utilities from it's manual book (usually available at it's case/box), restore it (usually by scanning it) to original factory configuration or scan a label that would enable all symbologies.
1/4/2008 9:55:54 PM •
Opticon...
Answered
on Jan 04, 2008
No green ready light
There are two different type of port usually experience this particular problem.
1) If you use the scanner to com1 computer port
2) If you use the scanner to com1 cash register
The only way to settle the situation is to use the manual barcode scanner default settings.
1) Setting up default for com1 scanner
2) Setting up default for com1 cash register.
If you barcode still experience the problem you need to contact the manufacturer on that model or the reseller where you bought the said device.
Probably, the device being situated in critical effects that your scanner would not able to determine where it will send the data from your barcode scanner.
Please rate me solved if you like my suggestions.
Best regards,
Philip
11/17/2007 3:35:15 AM •
Opticon...
Answered
on Nov 17, 2007
Is there a way to
usually there are no settings as most computers see the barcode and crdit card scanners as keyboard/input devices. unless the manufacture has additional software and drivers the device is simply an input capture device.
3/23/2011 7:09:52 PM •
Opticon...
Answered
on Mar 23, 2011
