20 Most Recent
Roland TD20SX V-Classic Electronic DRUM ESSENTIALS BUNDLE Questions & Answers
TD20 backing voice plays on everything no matter what...
no matter what pad i hit the slapbass wave sound would play..
i unplugged all midi connections..
i turned the backing parts volume down..
i removed all my patterns from the kit...
i did a factory reset...
and there it was STILL!! dang it!!
after calling Roland and hearing they have never heard of this problem before
i took the unit apart and removed the backup battery.
( didnt want to send my unit off..omg i am broke enough.)
i also pulled the ribbon cables from their holders and and then i put everything back...it factory reset when i turned it on..
(yes i had myown personal backups beforehand)
BooM! Mr TD20 was back without that slapbass wave! yahooo!
i dont know what caused it, but i was doing some major midi routing
experiments with my comp thru Sonar6P, midiman 4x4, and my Roland
VSynth...and it did just kind of show up at some point when i had the
backing voices turned down i guess..
it still persisted even after the TD20 was turned off for a day and half
and i turned it back on to see if it still was happening...yep, i was
hoping it would fix itself..lol..i hope this helps fellow
musicians..play on!!
Hi. Can I use the second pedal on my Roland BK5 to scale up the key one semitone at a time?
Yes, you can use the second pedal on a Roland BK-5 keyboard to transpose the key of the music that you are playing up or down by a semitone at a time. To do this, you will need to press and hold the second pedal while playing the keyboard. You can also use the transpose function in the settings menu of the BK-5 to adjust the key of the music that you are playing by a specific number of semitones.
1/5/2023 4:04:49 PM •
Roland Music
Answered
on Jan 05, 2023
I need a circuit diagram for a Roland MA-15D speaker please?
It's a Chinese made Roland and no service information is available as when a fault is found the main board is replaced, eliminating the need for service information.
I would check that it is a stereo out jack and not mono. If it is a stereo out, check that both input phonos work. If they do, replace the faulty socket or damaged pcboard.
11/17/2022 6:14:26 PM •
Roland Music
Answered
on Nov 17, 2022
MY Roland Handsonic's digital display is gone
Hell,
there is no display on your Roland Handsonic because the screen inverter or screen board panel is faulty. This has to be replaced for you to see your digital display again.
So its either you use it like that without the display or you take it to a repairer for fixing.
Take care.
7/11/2022 8:54:01 AM •
Roland Music
Answered
on Jul 11, 2022
