20 Most Recent Roland Boss BR-800 Digital Recorder Questions & Answers
Yes. There should be a mono out on the unit and that's what ypu'd use.
Roland Boss... | Answered on May 17, 2015
the floppy drive never had a cleaning disk. if it doesn't work it can be replaced.
Roland Boss... | Answered on Feb 18, 2015
There should be a fuse on the power supply board inside the unit. If it is not that then it is most likely the board itself. You can get a replacement at Allied Electronics.
Roland Boss... | Answered on Nov 30, 2014
Hello Alan.
Yes you can connect your ME-25 to the BR-800, there is no risk to damage any. it is simple, you may use both outputs of the pedal and send them via two normal 1/4 plug guitar cables to two of the channels of the DR (i.e. ch 1 & 2) to avoid an initial saturation of the recording preamp, set the input sens pot at minimum and the sliders very close to minimum as you try playing and looking the levels on the display and adjunting them to the optimum.
To connect the DR to an amp you should use the pair of RCA jacks named LINE OUT (R & L) depending of the amp you have there might be the need for a conversion cable or plug adapters. The out put of the DR is stereo, and if you want to use a guitar amp, commonly mono, you should mix both channels to send them to one input, this can be done by putting two 10 kohms resistors in series with each channel output and joining the other end to the input.
Good luck and best wishes
Roland Boss... | Answered on Nov 26, 2014
Uninstall any HP device and try it. Then reinstall the HP device.
Roland Boss... | Answered on Dec 17, 2012
Remove power supply or battery for 5 minutes. Apply power while holding the on switch in, this usually resets most electronic devices to their factory default condition. Then look again.
Roland Boss... | Answered on Sep 04, 2012
Best to use the line out jacks. The phone jack is stereo and you would have to use a wye cable for that.
Roland Boss... | Answered on Jul 01, 2011
Weak batteries or power adapter would cause this.
Roland Boss... | Answered on Jun 29, 2011
Go to this site:
http://www.vsplanet.com/ubbthreads/
In the forums tab, scroll down to the BR8 forums. There is software to convert the BR files to PC readable. You can find discussion there of where and what to get.
Roland Boss... | Answered on Jun 18, 2011
Yep, that's what its supposed to do. You set the start (and stop) points and it punches from play to record so you can pick up just before where you goofed up. I'd suggest you put the punch-in point at a natural transition to what you're recording - like a pause in guitar part of between verse/chorus of vocals. If you try to punch into the middle of a guitar run (for example) the results may be less that satisfactory. Make sure you sing/play along with the playback so the transition sounds natural - don't try to just pick up after the punch.
Roland Boss... | Answered on Dec 08, 2010
You don't tell us where you're located, but the best bet would be either Ebay, Craig's List, or Reverb.com
Roland Music | Answered 2 days ago
Unfortunatly the impact from a fall can lead to numerous problems ranging from a broken fuse to a disloged power supply to a cracked board. I'd suggest taking it into your nearest Roland authourized service center to get it checked out. If you're not trained in electronics you can do more harm than good poking around inside the amp. https://www.roland.com/us/support/service_repair/service_centers
Roland Music | Answered on May 17, 2019
Roland Boss BR-800 Digital Recorder Logo
24 questions posted
Top Roland Music Experts
Michial Gueffroy
Cameron Lewis
Cameron Lewis
Level 1 Expert
Thomas F. Schneider
Are you a Roland Music Expert? Answer questions, earn points and help others
View Most Popular
Roland Music
  • Roland Music
Most Popular Question
boss br8 no power fuse inside machine
  • Music
