20 Most Recent
M-Audio Axiom 25 2nd Gen 25-Key USB MIDI Keyboard Controller Questions & Answers
Using m audio axiom25 midi with RolandRD700NX
Hi you'r NOT stupid, it's just that Roland doesn't like people mixing stuff up, they want you to use their gear only, accordingly, you must dump the Axiom, MIDI and get a Roland one... You really need to keep it all one brand as it were then there will be NO problems at all... Not all MIDI are created equal, as it were, and using the Roland one will allow full functionality to be provided by the input unit. This unit is more the more modern one of the RD700 series, and the older, RD700 wan't all that fussy about the interconnections but your new one is. In any event I do know that sticking within the same brand name always sorts things out for whatever reason?
M-Audio controller. How do I fix a loose sub port?
I just had the same issue. The temporary fix I used worked for 2 years. I just stuck a small paper clip or safety pin in the corner of the port, and then plug the cable in. If those are too big just use something you can use to make the plug fit tight.
It finally stopped worked a couple of weeks ago, so I just bought a new USB port at an electronic store for $1.50 and soldered it on. I had to buy flux which was $3.00.
$5 and an hour of time after squeezing 2 extra years with paper clips. Priceless.
Just make sure you have a cold beer to solder with. Sticking drinks in a freezer wrapped in a wetpaper towel for 15 minutes is like a reverse microwave for beer.
Keep losing midi connection to laptop.
If your just using as a controller don't set the output. You only need to set the input.
Make sure the channel your using is armed as well. The button below mute & solo will be red if it is.
I'm using an oxygen 49
There are several reasons why this could be happening, assuming it's Windows, not MAC.
-Check to make sure the OUT port isn't set. You only need IN for basic controller use.
- Make sure the channel your using is armed (button below Solo & Mute should be red) [this is the most likely problem]
Another problem is the USB power settings in Windows. The default is set to allow the Computer to monitor and turn off USB ports automatically to save power. But it doesn't turn them back on automatically. You'll want change these settings regardless to help reduce latency issues.
-Go to Device Manager> USB Controllers> double click & change power settings to OFF for all Root Hubs.
Here is a guide to help optimize Windows to lessen Latency, Dropouts and Clicks /Pops. It's for Studio One, but the settings are the same for Windows.
You might want to give Studio One a try. I've used everything and by far Studio One is the easiest with the least issues. The free version is better than most DAWS paid versions. It can definitely help eliminate a lot of the everyday headaches that come with using Abelton, Cubase, Protools and even FruityLoops (which is pretty gay anyway).
M-Audio is also notorious for USB hardware related issues. A lot of times I find it turns out to be a bad connection between the plug and keyboard port, which tends to wear after awhile. It can go unnoticed because it still fits tight enough to get power, but not enough to keep the board fully functional.
Hope this helps.
Peavey cs1000 x
The most likely case is that one of the main output transistors (if which there are many) is shorted. When the protect circuit senses DC on the final output, it will not allow the output relay to come on to protect the speakers from raw DC. With the power removed, you can check between each outputs Emitter and Collector and you will probably find close to zero ohms. From that point you need to unsolder each of the pins of the bad channel until you find the shorted device(s) and replace them.
2/7/2024 9:32:20 AM •
Music
Answered
on Feb 07, 2024
