20 Most Recent
Alesis M1 Active 320 USB Speakers Questions & Answers
Right speaker sounds louder than
Besides checking balance, cables and length of cables can cause that. If cable is weak, or if one side is longer than the other, you'll get that effect
The power always is on,
Does the knob click or have a detent when you turn if fully clockwise? You should feel a little resistance before it is fully to the off direction. There is a blue LED that indicates power is on... note that it might take a little time to fully go out when switch is turned off as the capacitors do hold a charge and LED's take very little to illuminate. If both units are acting the same, I suspect you may not be turning the knob quite hard enough to turn off the switch... you should not force it, but it will offer a bit of resistance.
CANNOT GET HPh204 speakers to work via usb
Usual problem is that in the Windows control panel under "Sounds and devices" the speakers are not the default and the settings are for the internal speakers. If the M1 are not in the list in the "Sounds and devices" you don't have the drivers loaded properly.
Anybody ever figure out the Alesis DM10 module blank screen with some led lights on?
Try a reset before going to assistance:
There are two ways to reset the DM10:
To
fully restore the module to original factory settings, hold the
EXIT and
STORE buttons while powering on the module.
To reset only the
kits, sequences, or trigger settings:
- Press UTILITY to enter the main Utility Menu.
- Press SYS (F4) to access the Accompaniment Settings.
- Press INIT (F2) to access the reinitialization page.
- Use CURSOR UP/DOWN to move through the following menu items:
- All Kits: All of the module's kits and their settings will return to factory default
- All Sequences: All of the module's sequences and their settings will return to factory default
- All Trigger Settings: All of the module's trigger settings will return to factory default
- Highlight the option you would like to reset, then press EXEC (F4).
- A window will appear asking you to confirm your choice. To confirm and reinitialize the selected settings, press YES (F1). To Cancel, press CANCEL (F2 or F2).
6/27/2021 6:00:01 PM •
Alesis Music
Answered
on Jun 27, 2021
