20 Most Recent
Heartland 3160 Top Freezer Refrigerator Questions & Answers
The refrigeration part of the
its can be defrost problem.But still whats the exact model number of the unit.As per that the exact problem can be detected.
Is it old model or new model.?
Is there any water leak noticed in fridge section , then yes its defrost issue.------
--- Keep updated with details.
5/4/2011 11:08:01 PM •
Heartland...
Answered
on May 04, 2011
Russell Hobbs Fridge not working?
Humming is a classic sign that the start / run capacitor for the compressor has failed. Call for service, have it checked for gas and condenser cleaned.
How to remove drip tray at back of aeg fridge
On an AEG SANTO 3533, the tray sits on top of the compressor. There is a short metal "tunnel" on top of the compressor. The tray has a plastic clip in the middle which goes through the tunnel and latches up on the other side. To remove, reach to the back of the metal in the middle of the tray, press the plastic clip firmly down, and pull/wiggle the tray backwards horizontally to remove. Needed a torch to see clearly on mine. One of these things that's easy once you've done it once.
When Should You Consider Copper for Water Storage?
Copper has anantibacterial effect. Studies recommend storing water in copper containers for several hours before consumption to maximize this benefit. Some research suggests 48 hours. perhaps explore dedicatedcopper water bottlesfrom reputable sources for optimal water storage.
This refers to water, not juices.
