can you please post some pics of all the filter parts that need to be put back together to get an idea what type of filter it is ??
Thanks
G Man
It seems that the efficiency of the fridge has dropped as there is frost forming within the system due to a possible failure in the control circuit or the auto defrost timer.
It can also be related to a failure of the circulation fan or the thermostat.
Shut off fridge for about 6 hours and if it cools then the defrost timer must be checked along with the heaters.
POTENTIAL BEKO REFRIGERATOR FIRE RISK AND RECALL NOTICE I would
normally give a pointer to articles I have already posted this response on, but
as this is such a potentially serious matter, I have posted my entire response
here for you.According to
several sources I have checked, including the London METRO magazine ( http://www.metro.co.uk/news/868330-beko-fridge-freezers-fire-risk-warning-issued-to-homeowners-amid-recall ) The MODEL numbers
(not serial numbers) affected by the recall are as follows:CDA543FX
CA5411FFS
CDA752FS
CDA645FW
CA5411FFW
CDA752FW
CDA647FS
CA5411FFX
CDA752FX
CDA647FW
CA7014FFX
CS460FF
CDA648FS
CA7015FFS
CS460FFS
CDA648FW
CA7015FFW
CS460FFSD
CDA653FS
CA7015FFX
CS461FFW
CDA653FW
CDA539FS
CS461FFS
CDA653FX
CDA539FW
CSA4706FFX
CDA659FS
CDA539FX
CSB4606FFS
CDA751FS
CDA543FS
CSB4606FFSD
CDA751FX
CDA543FW
CSB4606FFWFrom what I
can ascertain, the fridges affected were manufactured between January 2000 and
October 2006 (So, after shipping and sitting around in shops, you can probably
extend that margin to machines SOLD between 2000 and 2008)If you go to
the BEKO website, there is a link to check your serial number:https://refsafety.beko.co.uk/I have to
say.Regardless of dates and matching
serial numbers, if I had an affected model,
I would be checking with BEKO anyway!!
Please check gas pressure. There is short of gas or no gas in the system. Due to this compressor is getting overheated and taking longer time for restart.
And due to above, no frosting retain or good cooling in fridge compartment.
Hence, call repairman to check leak test and rectify.Thanks.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
I would agree with the the last poster just one final thing to check make sure the bottom of your fridge in the back of your fridge is dust free dust builds up on the condensers and they get blocks and they don't work as efficiently and also make sure there's the correct space between the back side top and bottom of the fridge according to the specifications I don't have them with me but you should have them in your user manual if you have one.
Question edited for clarity and correct spelling of make and correctly Capitalised.
Question moved from 'Frost Refrigerators' to Beko.
Check the condenser coils are free of dust and debris.
Turn off for 15 minutes by removing the wall plug. This is a power reset if your unknown, unstated model has an electronic board.
Or it needs a new thermistor or a gas top up in which case you need a service call.
To remove the front control panel on a Beko GNEV322 refrigerator, you will need to follow these steps:
Unplug the refrigerator from the electrical outlet.
Locate the two small slots on the control panel, these are usually located on the bottom edge of the panel.
Use a flat-head screwdriver to gently press in on the tabs located in the slots, this will release the panel from the refrigerator.
Once the tabs are released, gently pull the control panel away from the refrigerator to remove it.
If the control panel still won't budge after following these steps, you may want to consult the user manual or contact Beko customer support for further assistance.
Note: Be Careful when working with electrical appliances, especially when unplugging them.
Question moved from Cars and Trucks.
You can try, but it has 4 wires for a reason, perhaps low and high speed.
Google
make model condenser fan
Unless it is the evaporator circulation fan? You fridge has three fans. There are many types listed here.
https://www.google.com/search?q=BEKO+American+style+fridge+freezer+condenser+fan
That is normally indicative of a failed gasket and not sealing properly. The warm moist air is sucked in and condenses to frost. You should be able to trap and grip a 2" strip of normal printing paper all the way around it.
It shows the thermostat, the housing and the knob. It Iooks like it probably has catches that lock into those slots on the sides. Put something like a butter knife in the side to release them and pull gently.
If you look carefully there is a small notch like lug at the center of the drain tray which latches by itself on the tray cover. You need only a gentle action to puch this down and pull to remove the tray. Think as opening a cupboard drawer by with a small downward push before you pull.
