20 Most Recent
Sierra International 18-4310 Marine Powerhead Gasket Set for Johnson/Evinrude Outboard Motor () Questions & Answers
Steering shaft stuck and will no move left or
Try to tun shaft with vice grip or Stilton wrench(bobbyaan spanner)put spanner nearest to end,try not to damage shaft.if shaft will not turn you will probably have to cut cable and knock out from other side
12/11/2013 10:32:24 AM •
Sierra...
Answered
on Dec 11, 2013
I have a evinrude 28hp outboard which is not
Check pump housing and plate for wear,make sure aluminium housing not corroded under plate. Suggest fitting electric drill to drive shaft and emerse lower unit in bucket of water.make sure drill doesn't get wet.is motor going into gear,maybe splines are rusted off in crankshaft,could also have holes in inner exhaust side plate
12/9/2013 2:38:30 PM •
Sierra...
Answered
on Dec 09, 2013
Suzuki outboard
Check and clean carbs. If same problem persists rebuild or change full pump. Firstly ensure clean plugs,and fuel filter. If you hook up a inline fuel pressure gauge, then run. You may have low press output, at cont full load. If so you need to open your vapor separator tank. Check and clean high presure pump and pre filter. You need to clean and inspect needle and seat. Than repeat test as outlned above.
I just bought a new boat and need to buy a boat
Never buy a trailer with the same capacity as the weight of your boat! This can be very dangerous! Instead, make sure the trailer's capacity is at least twice that of the weight of the boat, all your gear, and the boat's motor.
12/5/2023 6:58:35 AM •
Boating
Answered
on Dec 05, 2023
What is the size of a small yacht?
Small yachts, also known as Silboats or Cabin
Cruisers are 20-40 feet. There are of course larger Yachts that can get to over
100 feet, also known as Mega Yachts.
11/15/2023 8:08:55 AM •
Boating
Answered
on Nov 15, 2023
