20 Most Recent
Sony 1/3 Sony Super HAD CCD Outdoor IR CCTV Security Camera Questions & Answers
In my 4 camera surveillance system two cameras stopped working
The screen should say a message similar to "VIDEO LOSS" if it does The power packs or multi power supply to your cameras are easiest to check for starters. Unplug the power to a working camera and plug it into the non working camera close to the dvr. If the camera that didn't work came on, then the power pack is most likely the problem. If it didn't have a message saying "VIDEO LOSS" then it may be the sensor that switches to day/night vision. I have had cameras that when it switches to night vision the screen goes black and unplugging in the power to the camera and re-plugging it in gives it a boost and then comes on. If switching the power from a working to non working camera don't work get the ladder out and unplug and re plug in the connectors at the camera in case it is a connection there. Last if that didn't work would be to take the camera that don't work off and plug it into the end cables to a working camera, if it works then I would suspect the cable to the camera to be bad. Just a process of elimination.
Sony EVI-D30 power and standby flashing
Sony EVID30 NTSC Color Camera
the battery inside is dead.
lost these? NIB, new in the had this too.
AC power adaptor (1) <<<<<???
Audio/video cable (1)
Remote commander (1)
a 2010 cam
no battery lasts 12 years for sure this one parked in dusty box for 12 years,? even 2 years ignored it can fail. hard.
new battery time.
4/12/2022 10:00:37 AM •
Sony Home...
Answered
on Apr 12, 2022
My monitor sony ssm-721 rolls until it warms up or
Fixed mine! Take off the monitor from the dash. Take the cover off the monitor. There are four seperate white plastic turn dials available inside the case. Each of these have seperate controls the ones on the top are for brightness and focus while the ones on the bottom of the casing are for vertical and horizontal hold fine tuning, use a screwdriver to adjust. Save you money and do this yourself it's easy as pie.
7/25/2014 3:23:12 PM •
Sony Home...
Answered
on Jul 25, 2014
What would be better, lightning arrestors or surge
Hello
The lightning arreseters and surge protectors are of different use. Lightning arrestors are of course high voltage dischargers, where surge protectors are use in connection with the supply voltage of the device to be protected. A lightning arrester cannot give protection against line surge voltages. Line surge voltages are the result of various other electrical equipments, connected to the specific line, susch as high capacity motors, or so. When a motor is switched on to a line, its winding will take a tremendous amount of current during startup, and due to this a spike will be induced on the line, which may cause damage to delciate electronic equipents. Therefore, to protect and electronic equipment from line surge, surge protector is better. A lightning arrester also can be installed. As we know, there will be trillions of volts during a lightning discharge. Lightning arresters are not discharging this at one time, but discharges it slowly to ground, and thus avoiding the chance of a sudden discharge. Nothing of the above can prevent a sudden lightning discharge at all. OK.
4/28/2011 4:16:48 PM •
Sony Home...
Answered
on Apr 28, 2011
