20 Most Recent
Vantec CB-IS100 IDE to SATA converter IDE / EIDE, Serial ATA, ATA-133 Drive Case Questions & Answers
Can Vantec CB-IS100 IDE to
It attaches directly to the drive, whether it be IDE hard disk or CD/DVD, and is used in boxes that already have sata connectors on the MB. Connector attaches to drive, cable from connector attached to drive to sata connection on MB.Note: Sometimes these
may not work (for a variety of different reasons).Here is a link to one seller of the converter, read through the reviews. While it works well for most, sometimes there are issues.
http://www.newegg.com/Product/Product.aspx?Item=N82E16812232004
My Nexstar 3 drive will not load. Any Suggestions?
Let's start with the basics:
1) Is the drive getting power; is the supply correct and the connection firm? Does the drive spin-up at all?
2) Is the data cable known to be good?
3) Is the port on the computer known to be good, mechanically and electrically?
4)Does the OS support this device, or does it require additional drivers?
If it worked before, 9 times out of 10 a bad connection somewhere is at fault. Even if software or data corruption is involved, the cause is almost always an intermittent connection.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
