20 Most Recent
NEC Nippon Labs Premium High Performance HDMI Cable 10 ft. HDMI TO HDMI High Speed Networking Cable A/V ... (HDMIHR10) Questions & Answers
What software or cords do I need to get/run in order to get files to transfer to/from the NEC Mobilepro 770, or even get internet?
The NEC Mobilepro 770 is a legacy device that was released in the early 2000s and uses Windows CE as its operating system. Since the device is no longer supported, it may be challenging to find software and drivers that are compatible with modern operating systems like Windows 10. Here are some steps you can take to transfer files and connect to the internet:
- Get the necessary cables: You'll need a USB cable to connect the Mobilepro 770 to your Windows 10 PC. The cable should have a USB Type-A connector on one end and a mini-USB connector on the other.
- Install ActiveSync: ActiveSync is software that allows you to synchronize files between your Mobilepro 770 and your PC. Unfortunately, ActiveSync is no longer available for download from Microsoft, but you may be able to find an archived version of the software on the internet. Install ActiveSync on your Windows 10 PC and connect your Mobilepro 770 to your PC using the USB cable. If the device is recognized, you should be able to transfer files between the two devices.
- Connect to the internet: The Mobilepro 770 has a built-in Ethernet port that you can use to connect to a wired network. To connect to the internet, you'll need an Ethernet cable and a wired network connection. Plug one end of the Ethernet cable into the Mobilepro 770's Ethernet port and the other end into your router or modem. You should be able to browse the internet using the Mobilepro 770's built-in web browser.
- Install additional software: The Mobilepro 770 comes with a basic set of software, but you may want to install additional software to make the device more useful. You can download and install software from the internet, but make sure it's compatible with Windows CE and the Mobilepro 770.
Keep in mind that the Mobilepro 770 is a legacy device, and its performance and capabilities may be limited compared to modern devices. It's also possible that some of the software and drivers you need may no longer be available or supported.
NEC Versa LX Screen will not come on
NEC Versa LX Screen
no model told screen, a monitor is it"?
the 1998 PC that? has no change at all to run
zero.
Pentium II (p2) relic,
no modern OS run on it
the coin cell battery and huge battery are toasted.
hdd is bad.
it has zero value now, and to fix it will be costly .
the CCFL back lamps are dead.
what is there to like, sure free in a garage sale.
zero value. ,try moving from 1998 to 2010 to gain a future.
I can not play movies
Hi..
AMR (Adaptive Multi Rate) is common audio file format for mobile devices like mobile phones, laptops, portable recorders.. etc.
in fact totem movie player can't play any amr files (files encoded in amr codec) by itself. Totem Player depends on Gstreamer libs, which haves necessary media handling components .
from your post its not clear that whether your totem can't play movie files from the very beginning or just you can not play movies recently.
your totem player may lacks Gstreamer library files or somehow your Gstreamer libs got corrupted recently.
Reinstalling Gstreamer Library file may help you.
you can find
latest source version of Gstreamer on this page (more detailed download of Gstreamer can be found on
http://openports.se/multimedia/gstreamer-0.10 )
How add a NEC Multisync 70GX monitor to my PC win10
connect it to computer and power source and then right click anywhere on desktop. choose display settings. May need to scroll down in your display settings, but windows 10 will automatically detect additional displays from that screen. Then you can choose extend or duplicate and choose primary and resolution.
How to make wifi extender through nec atren wm3500r in home wifi?
Firstly, check for reset button on your WiFi extender, press and hold for few seconds till all lights off.
Search for WiFi SSID and connect your laptop or mobile, browse for given ip on extender in browser, give it's password and follow the wizard to complete setup.
