20 Most Recent
ASUS K52F-BBR9 Notebook Questions & Answers
No sound on asus k52f
Go start / control panel / Smart Audio / (wait 15-20 second ) ;) open audio director and select Multi stream on the right side you can check sound speaker or headphone. then exit, go control panel / sound / then select speakers as default. that's all. I hope this instruction help you. Best regards from Georgia :)
How do I turn off backlit keyboard
Hi! Usually it is Fnc + F2 or Fnc + F3 or Fnc + F4. Check it out! (By Fnc I mean the "Windows" key on the low left side of your keyboard)
Laghaim
Try to set compatibility for vista or even older (e.g. XP) and tell us if this works!
Netbook reset
does the powersupply have a led showing it is working? if so does the netbooks power indicator show it's plugged in? If you have lights in both places try removing the battery and see if it turns on while plugged in. Otherwise you are looking at a hardware failure.
My Asus laptop model K52J battery icon is blinking
It sounds like you're battery has died, has you've possibly over charged it. You will find new battery's online cheaper than actually going to some sort of shop. Just simply type in the model name on google and add battery. :) Hope this helps
Rescue password when opening type password cannot bypass
You can remove or change the Window's User or
administrator's password and privileges. You need access to a computer with
Internet access to download the Hiren's Boot CD and burn it onto a CD.
Then insert this CD into the laptop/computer and boot up
the laptop-computer with the Hiren's CD and follow the instructions.
There are very useful utilities CD and it a Linux boot CD
which contains quite a lot of Utility programs including a password removal
program.
Click on one of these links to
download HIREN'S
BOOTCD :-
http://www.hirensbootcd.net/
http://67.20.82.163/
How to boot DVD
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key but will differ depending on your computer and Bios. Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system. Note: After you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults after windows has loaded If you are putting windows XP on your computer your computer will automatically restart it might restart 2 times one to finish the installation the next will be because the operating system is loaded and will boot from your cd\dvd.
Asus k52f laptop hdmi port no sound
Step 1:
Plug your TV into the HDMI port.Step 2:
Right click on the audio icon on the task bar, and the click "Playback devices".Step 3:
Choose your TV and click "Set default"
When I updated my os to windows 8, why did I loose some of the functions of my touch pad?
You have to go to the computer manufacturer's website to look for the drivers. Make sure that they are for Windows 8. After installing the drivers, install RadarSync to automatically update them. You can even try installing RadarSync before you look for the drivers because if you did the update and not a clean install then RadarSync should detect the generic drivers in your computer and it will scan for their latest drivers.I hope this helps!David
The slimtype dvd drive in my acer aspire 7739z doesn't work
check: right click on my computer in desktop then choose manage. then click on device manager then if u see a yellow symbol then right click on it and update the driver through internet then it will say u what u have to do exactly.good luck
