20 Most Recent Linksys by Cisco Cisco Valet Plus Wireless Hotspot M20 Router Questions & Answers
0answers
Verizon dsl and cisco valet
Connect your computer directly to the Internet modem and make sure that you have Internet access directly from the modem. If that is working properly then connect the modem to the Internet port on the router. Connect the computer to port 1 on the router. Reset the router and configure it manually. Here is link which will help you troubleshoot Cisco Valet M10 or M20 router
7/4/2015 11:30:27 AM • Linksys by Cisco... • Answered on Jul 04, 2015
Haveing problems with moderate nat
Open up the Browser interface to your Linksys (http://192.168.1.1/ if you left it as default), and go to your Security section. On the Filter tab, check the box beside "Filter NAT Redirect" and "Save" at the bottom.
If you have an Xbox and you keep the settings as automatic in the network area, you should have an open NAT.
11/19/2013 7:34:29 AM • Linksys by Cisco... • Answered on Nov 19, 2013
0answers
Cant get it to reset
What have you tried
2/15/2013 2:40:47 AM • Linksys by Cisco... • Answered on Feb 15, 2013
I have an M20 Valet
This is not an easy solution. They do sell range extenders that plug into wall outlets and extend range, but they are not very reliable. Another solution is to configure another wireless router to be an access point. This involves turning off DHCP (the service that give out IP addresses) and just relaying your original signal from the Valet. The problem with this solution is that wireless routers only have one radio, so in order to send and ercieve information from the original router, it constantly needs to switch modes from listening to sending. This cuts your bandwidth in half. the best solution is to run a network cable to a wireless access point (not a router) located on the outer edge of your wireless network right now. Give it the same name. This way, as you walk with a laptop from one area to another, it will seemlessly switch from one access point to another, with no interruptions.
7/11/2012 7:54:16 PM • Linksys by Cisco... • Answered on Jul 11, 2012
Reinstalling cisco m20 0n vista
Is it re-installation of complete network or you are just trying to add Vista computer to the network?Is it a complete re-installation then you can reset the router to factory default settings and then try to reconfigure it.You can run Cisco connect software on the main computer or you can also reinstall it manually,Read how to reconfigure router manually,If you trying to connect Wireless Vista computer to the network then you can simply search for the WiFi and then join the wireless network on Windows Vista computer
6/5/2012 5:10:49 PM • Linksys by Cisco... • Answered on Jun 05, 2012
My son reset m20 valet
log in to the router and reconfigure the router.
type in 192.168.1.1 on the address bar, or what ever the router ip is, then log in using the default login user/password as admin
7/25/2011 2:37:46 AM • Linksys by Cisco... • Answered on Jul 25, 2011
I can't seem to connect
This article contains some good information I hope it solves your problem.
good luck
6/12/2011 6:44:57 AM • Linksys by Cisco... • Answered on Jun 12, 2011
I cant get my NAT
Hooking up an Xbox with Linksys routers:
Open an Internet Explorer browser page.In the address bar type - 192.168.1.1Leave username blank & in password use admin in lower case...Click on "Applications and Gaming" tab and then click on "Port Range Forwarding" subtab...1) On the first line in Application box type in ABC, in the start box type in 88 and End box type in 88, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box...2) On the second line in Application box type in PQR, in the start box type in 3074 and End box type in 3074, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box...3) On the third line in Application box type in XYZ, in the start box type in 53 and End box type in 53, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box and click on Save Settings...3) Once you return to the set up page click on the Security tab and uncheck Block Anonymous Internet Requests and click on Save Settings...4) Click on set-up and change the MTU Size to 1452 and click Save Settings...5) Goto the XBox Network Settings and IP Address Settings and select manual IP Settings and assign the following on your XboxIP Address :- 192.168.1.20, Subnet Mask :- 255.255.255.0, Default Gateway :- 192.168.1.1...6) Also assign the DNS Addresses on the XboxPrimary dns :- 4.2.2.2...Secondary dns :- 192.168.1.17) Turn off your modem, router, and Xbox...Wait for a minute...8) Plug the modem power first, wait for another minute and plug the router power cable, wait another minute and turn on the Xbox and test it...it will connect...
here is a website to help you setup the Xbox Live:http://support.xbox.com/support/en/us/xbox360/
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
4/28/2011 2:20:38 AM • Linksys by Cisco... • Answered on Apr 28, 2011
[email protected] mnokia 2670 security code
you can try this site http://www.unlocking4u.com/ to get the codes for your phone.
4/17/2011 7:54:50 PM • Linksys by Cisco... • Answered on Apr 17, 2011
2answers
Connecting new HP desktop - hardwiring into CISCO
Make sure that the plug is in thr correct port of the router. The ethernet cable going from the modem to the router should be plugged into a port labeled WAN or Internet. Then, after that's done, unplug your modem for about 30 seconds or so to delete the MAC address saved in the modems memory. Modems can only "speak" to one device, and they always remember the address of the device they were "talking" to. You need to clear that memory out so that the modem can address the new device, which is the new router in your case. hope that this was helpful.
3/2/2011 7:15:37 PM • Linksys by Cisco... • Answered on Mar 02, 2011
I have the valet M20,
Just power cycle your router and restart the computer.
2/22/2011 5:35:45 AM • Linksys by Cisco... • Answered on Feb 22, 2011
Changing my nat type on
There are two things you could do from the routers end..
1) You can take the IP add of your device( X-box, PS3) and then contact the device vendor(Xbox or PS3) and ask them to give port numbers for your device. Once u get the port numbers you can either open ports on the router by logging into the router interface using your Default gateway of the router or you could put the IP add of your device in DMZ on the router. Basically this will keep the device out of the firewall of the router( Which is the main reason for this issue). 2) If the first step didnt work you could disable the firewall on the router. If both the steps didnt work you could check if your router has any firmware update or it has to be reset and re-configured and the above steps should be re-done.
Hope this helped.
2/17/2011 5:57:29 AM • Linksys by Cisco... • Answered on Feb 17, 2011
Xbox live NAT is either
moderate...
2/6/2011 9:03:23 AM • Linksys by Cisco... • Answered on Feb 06, 2011
Linksys by Cisco Cisco Valet Plus Wireless Hotspot M20 Router Logo
36 questions posted
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Linksys Computers & Internet
Most Popular Question
m20 valet
  • Computers & Internet
