One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO THE HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
If you are talking about problem with your password
You need to prepare:1:A blank CD/DVD or USB flash drive2.A computer which can link to internet3.A program called Windows Password Recovery 6.0Get started with this 3 simple steps:Website: http://lost-password.net/products/windowspasswordrecoery.htmlStep 1 - Download windows password recovery utility and install it.Step 2 -Burn your Windows Password Reset CD:To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.Step 3 - Put in your newly created CD and remove your Windows password.hope this helps
http://majorgeeks.com/download.php?det=5710UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem also has a bios reset tool which can remove your password and bios password you will have to burn it to a disk as an ISO then you will have to boot from the disc During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed your password you will have change first boot back to your hard drive) Hope this helps
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test or replace all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard)) drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP: The options listed for 1st,2nd ,3rd Boot device include:IDE-0 means Pri master ?IDE-1 means Pri slave ?IDE-2 means Sec master ?IDE-3 means Sec slave ?
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is
Depends on what you are using the hard drive for. For example if this hard drive is going to be used for multimedia then I would recommend a hard drive around 120Gb to 1TB, but if it's for a small office with MS Windows XP installed it should be just enough to host the operating system and a limited amount of programs, hope this help, best of luck
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
86 questions posted
161 Questions
116 Questions
22 Questions
19 Questions
20 Questions
