20 Most Recent Craig Electronics Recertified - Craig CLP281 Black 7" Netbook Questions & Answers
Forgot lock pattern on android? Here's a way to reset it.
Enter wrong pattern 5 times and wait for 30 seconds.
Select "Forgot pattern" and enter your gmail account username and password.
Make sure you use the same account that was used to activate the tablet and double check the
password by logging in to that Google account in a browser on laptop or PC
If you don't have access to the original Gmail account, you will need to do a hard reset and
loose your settings and apps on the Netbook. The data on the memory card will not be wiped
though.
If all else fails...
Craig... | Answered on Mar 11, 2019
first solution,
I think your rom has gone bad/corrupt
solution is to plug it in to a laptop or pc let the computer download the drivers or download the android drivers from the netbook's manufacturers,make and model i.e search google info on back of device, then download their software to do a device reset or upgrade making sure everything you download corresponds to the windows platform of the laptop/pc your using i.e 64x or 32x
second solution,
download a newer version of the rom currently on the device i.e if 2.1 then get 2.2/2.3 etc there are all sorts of software made available online that are free to upgrade/downgrade any android try cynogen google search it but try the first solution first if that don't work the second will :) good luck.
Craig... | Answered on Feb 26, 2018
unfortunately there is no simple answer to this question, you would have to do some research on how to fix this, i have provided a link to point you in the right direction.
http://forum.xda-developers.com/showthread.php?t=1392593
Craig... | Answered on Dec 04, 2016
The only thing you can do is reset the computer
Craig... | Answered on Jul 12, 2016
Witch ISP are you with ? do you know how to login to your router using your id and pass provided via your ISP it could be you need to change the settings once logged in, Such as the channels and/or type of wifi ?
Get back to me and ill help you if i can
Craig... | Answered on Sep 26, 2015
Try this
http://www.craigelectronics.com/site/pdetails.php?id=641
You can use the same link to email the manufacturer
Craig... | Answered on Nov 08, 2014
The user manual is available at this link http://www.craigelectronics.com/site/pdetails.php?id=417
Craig... | Answered on Oct 20, 2014
Really? How about www.gmail.com in any browser? Of DL the GMail app from either itunes or the play store.
Craig... | Answered on Sep 08, 2014
The LG G3 is something spectacular compared to that net book lol. That net book is honestly too slow in my opinion but I would try jail breaking it if its on android and then putting a new more updated version, like android 4.0
Craig... | Answered on Sep 02, 2014
Try a soft reset to see if that helps
I believe that device uses the android os. You should be able to access the bluetooth settings (assuming it has bluetooth capabilities) from the settings menu. Normally you go to your home, click menu then settings. If yours has a connection tab, choose it. There should be a bluetooth option to toggle on/off.
Craig... | Answered on Aug 21, 2014
sounds like a network card issue in netbook can you plug and ethernet cord in thats wired to your isp and check and see if you can get on that way ? if you cant then it inside the netbook now adays the network parts are included in newer motherboards even for netbooks and laptops. it might need replacing , another way is to ping, your ip address but you have to get it from your isp(internet service provider) here is a video i found to help you
Craig... | Answered on Aug 19, 2014
plz call the company for support i didnt find a manual 1-866-321-7191
call customer service for craig 1-866-321-7191
call customer service for craig 1-866-321-7191.
before resettiing back up every thing she has in downloads, basically if u have external dvd/cd rom drive you can make a backup of her my documents folder the whole thing. as long as you have your own password to get in you can do this, might be a good idea to back up your data .
Craig... | Answered on Aug 18, 2014
You can perform a factory reset, but this will wipe out all user-level data on the machine.
Have you tried just pushing and holding the reset button on the underside of the machine?
Factory data reset: to erase all user's data on the Device as follows:
  • Click "Factory data reset" button to enter.
  • Click "reset device" button.
  • Click "Erase everything" button to start reset.
  • Wait until the device finishes the reset by itself.
The Device will turn off automatically. (It takes a few minutes).
1. restart windows system from login page.
2. before booting to "Acer" press immediately Alt+10 and continue pressing until
"windows prompt: loading". (this is before the Windows Logo)
3. you will arrived into two (2) options.
-Reset or restore factory settings.
and
-second is restore system only.
note: the second option will restore the system without and boot to normal without password
plus back-up the data and will be save by default directory c:\backup (this is where file save on documents, music, video and others)
-the first option will erased all data and format the system and install fresh windows 7 starter
and install the drivers of the netbook acer -aspire one.
4. wait for the system to finish its task under option 2 then it will restart or reboot.
5. process of resetting the password will be done. you can now type a new password for you
windows system.
Craig... | Answered on Aug 05, 2014
Get connected to the net.
Craig... | Answered on Jul 18, 2014
Craig Electronics Recertified - Craig CLP281 Black 7" Netbook Logo
49 questions posted
Top Craig Electronics Computers & Internet Experts
Tony Raia
Dayton Computer
Dayton Computer
Tom Chichester
Are you a Craig Electronics Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Craig Electronics Computers & Internet
Most Popular Question
locked out password need factory reset
  • Computers & Internet
