20 Most Recent Seagate (ST9100801U2-RK) (9W3638556) 100 GB Hard Drive Questions & Answers
When I plug the seagate
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x right click to reinstall drivers or if you can see your usb but its not working ports(com&lpt)right click update driver sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable, just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems if this fails you might need to get a usb 2 card and install it they are cheap and easy to installhttp://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=280406610810&ssPageName=STRK:MESINDXX:IT$1+ $2.50 postage You might get these on Ebay im not sure which country you are in this might guide you to one you could get this on Ebay if you dont have an account you will need to create one Add Email adress Add Bank Acc Add Credit Card also add your postal adress also add a paypal account when you get to the paypal login page at the bottom you will see new to paypal sign up tab paypal to create an account paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress be very specific when you type in the search always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described you will even see the pictures of your item so you cant make a mistake and get them home delivered hope this helps
7/22/2011 12:35:08 PM • Seagate... • Answered on Jul 22, 2011
Bag carrying the HDD banged
When a hard diskmakes a clicking sound and the computer does not detect it then the hard diskis faulty. This is commonly known as "The click of death".
There is no way of fixing this hard drive, if you need to recover your data,then there are companies that can recover data off faulty hard drives BUT itwill cost you an arm and a leg for their services.
6/27/2011 9:52:31 AM • Seagate... • Answered on Jun 27, 2011
Lost the usb cable to
you could get this on Ebay if you dont have an account you will need to create one Add Email adress Add Bank Acc Add Credit Card also add your postal adress also add a paypal account when you get to the paypal login page at the bottom you will see new to paypal sign up tab paypal to create an account paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress be very specific when you type in the search you will even see the pictures of your item so you cant make a mistake and get them home delivered hope this helps
4/9/2011 10:23:53 PM • Seagate... • Answered on Apr 09, 2011
I have a Seagate Desktop
It's probably easiest to just format it. Right-click the device under My Computer and choose Format. Or if you have a mac use, Disc Utility under Applications, Utilities.
3/26/2011 5:32:31 PM • Seagate... • Answered on Mar 26, 2011
2answers
My hard drive can't be
good day.....seems this tips can help you...trace the sata cable if properly connected...but i'm sure the ticking sound is an indication of defective hard drive...inside the hard has a mechanical arm that goes up and down...this arm read the data..... it's better if you buy a new one....
2/13/2011 2:12:54 PM • Seagate... • Answered on Feb 13, 2011
I have a Seagate 320
Hello Sir, I purchase the Seagate expansion portable drive 320 GB in Sep 2010. on 22 Dec 10 I had taken a back of my friends computer.Till 25 Dec 10 it was working fine Now the drive is not been detected by my computer. I kept all back up in the this 320 GB drive and i want all data to be recovered.My email ID is [email protected]. My contact no is 8144023475.Please advice me what to do.
1/7/2011 8:38:17 AM • Seagate... • Answered on Jan 07, 2011
I want to delete some folders previously backed up
At the moment you're just copying them to you trash bin.
Access the requisite file/folder on your external drive, RMB click, should give you a drop down menu. Choose the Delete or Move to trash option.
Alternatively, click on (highlight) the file then click on file at the top of your browser window and select delete from the drop down menu.
10/21/2010 4:00:25 PM • Seagate... • Answered on Oct 21, 2010
External HDD continuously beeping
The beeeeep beeeeep long twerps is the hard drive trying to spinup. drive don't beep unless they have died.
2/25/2009 7:57:53 AM • Seagate... • Answered on Feb 25, 2009
2answers
External Hard Drive won't show up!
i have a 500gb WD external drive and it wont show at all
10/5/2008 9:36:07 AM • Seagate... • Answered on Oct 05, 2008
Seagate 9w3638-556 100 gig usb drive working fine then blop front led is just blinking
Check the drive end to make sure it has poer and connectors are sound - you have he to take the case apart for this Change the USB connector for another asl anothercable is possible Go to Start/control panel/admintools/computer management/storage/removable storage See if the drive shows up
3/6/2008 11:16:31 PM • Seagate... • Answered on Mar 06, 2008
How to open the external hard drive case.
Hi, Most Seagates HDs uses Torx (type of screw head characterized by a 6-point star-shaped pattern). TORX sizes are using letter "T", followed by a number. A smaller number corresponds to a smaller point-to-point dimension of the screw head. These are also used by cellphones but smaller sizes. Normally you can buy a plastic box set containing 6 Torx drivers of varying sizes, hopefully one will fit you HD. However, if you are referring to the enclosure of the actual HD, they might or might not be using the same kind of screw. Hope this be of help/idea. Post back should you need further information. Good luck and kind regards.
9/9/2007 6:51:01 AM • Seagate... • Answered on Sep 09, 2007
How to delete backup on my seagate backup plus slim
Detailed steps to manage backup disk space
To delete old backups on Windows 7/8/10 using AOMEI Backupper, you need to set up Backup Scheme during the process of creating a backup. When your backup versions exceed the number of backup images files, AOMEI Backupper will delete older backup automatically. Step 1: Connect your Seagate Backup Plus drive or Central hard drive to the computer and make sure it can be detected by your computer. Step 2: Download AOMEI Backupper Professional, install and launch it. Step 3: Click Backup and File Backup subsequently Step 4: Choose the files and folders you want to backup and pitch on a path for it. Then, Click Schedule option and select Schedule Settingsfrom the following window. Step 5: Click Scheme option, tick Enable Disk Space Management and select whatever Scheme you need from the drop-down menu. Then, back to the main page of File Backup and click Start Backup. After that, your older backup will be deleted automatically when your file backups exceed the versions of backup image files.
2/26/2024 7:21:41 AM • Seagate... • Answered on Feb 26, 2024
Ive got a 8tb seagate its got a blinking blue light and wont connect to my Pc? Any help?
Did you initialize it?
7/3/2023 8:38:03 AM • Seagate... • Answered on Jul 03, 2023
Seagate Portable Hard drive 4TB, part number 2N1AP6-500
Hi, Please put your computer into safe mode before attempting to connect to the hard drive again. Safe mode turns some feature off when activated so whatever program is forcing the shutdown might have be paused when connecting to the external hard drive. Also, try connecting the hard drive to a non-laptop intermediary device and then connecting that device to your computer and attempting to access the hard drive folder within the intermediary drive. Thank you.
11/11/2022 2:11:28 AM • Seagate... • Answered on Nov 11, 2022
2answers
How to recover data from a dead Seagate external hard drive on my Computer?
Should be careful with the data file deposited on the Seagate external hard drive. your Seagate external hard drive might be dead or corrupted. In this situation, you might need to rely on data recovery software to get back data and files on the dead Seagate external hard drive. So you can rely on data recovery software to get back lost data and files when the Seagate external hard drive is dead and inaccessible. Data recovery hong kong technician provide the Ontrack EasyRecovery data recovery services are able to recover data and files from accidentally formatting, corruption, virus attack, dead, system crash under different situations Seagate external hard drive on Windows Computer. This data recovery software allows you to deep scan the dead Seagate external hard drive so as to find out almost all lost files with original quality in a short time. You can also rely on this software to recover files from dead/damaged Seagate external hard drive. The software supports to get more recover: Seagate External hard drive, data file, documents, PDF, Excel, photos, music, and videos any HFS, HFS, FAT, ExFAT, and NTFS format based data and file and more. It will recover data and file from all external storage devices that can be recognized by your Windows PC Computer/Laptop. Hope this helps you get to recover all your lost data and files from your dead Seagate External hard drive.
10/8/2021 1:02:33 PM • Seagate... • Answered on Oct 08, 2021
What enclosure is compatible with a Seagate Barracuda 7200.7 SATA Drive?
TRY LOOKING FOR TIGERDIRECT .COM THEY SELL STUFF FOR COMPUTERS
10/3/2021 8:21:41 PM • Seagate... • Answered on Oct 03, 2021
5answers
Need restore my RAW file system back to NTFS without losing any hard drive files?
There are two options for you to get your drive stuffs back right now: 1). Do not format this RAW file system external hard drive temporarily and plunge it to your PC. And then, choose and apply RAW external hard drive data recovery software to scan this drive and find your preferred drive files back as many as possible. 2). Directly consult some professional data recovery services from some data recovery companies or agencies. In the future, remember to save copies of everything important on at least two devices in case of any similar data loss issues.
1/5/2021 2:43:04 PM • Seagate... • Answered on Jan 05, 2021
Seagate (ST9100801U2-RK) (9W3638556) 100 GB Hard Drive Logo
16 questions posted
Top Seagate Computers & Internet Experts
Sean Wright
Sean Wright
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Seagate Computers & Internet
Most Popular Question
hard drive
  • Computers & Internet
