20 Most Recent Rockford Fosgate Power 351M Car Audio Amplifier Questions & Answers
Amp power wire is going to battery with a fuse,
The remote wire goes to the back of the radio to blue remote or pwr antena blue wire, solenoid? No idea ..Is the amp on all the time, the radio is suppose to turn it on and off..
3/7/2018 12:46:25 PM • Rockford Fosgate... • Answered on Mar 07, 2018
How can i tell how many watts my fosgate 351m power amp is?
Specifications Dynamic Power Rating (measured at 14.4V):
  • 4-Ohm Load: 175 watts x 1
  • 2-Ohm Load: 350 watts x 1
1/29/2013 5:39:33 PM • Rockford Fosgate... • Answered on Jan 29, 2013
3answers
I have this hooked up
You have connected it to the wrong power wire - one that is only active in service mode - first key position.
You should draw a wire directly from the battery (don't forget to add a 40 amps fuse on the wire) to the amps. If you don't want them constantly operational (you will have to manually shut them down) install a relay on the wire with the command coming from a wire from the instrument key position - second position of the key. Use a voltmeter to identify the wires.
10/15/2010 10:48:34 PM • Rockford Fosgate... • Answered on Oct 15, 2010
Installing a rf 351m
hook up the power to the battery and the amp then hook the ground up to the body of your vehicle then hook the RCA's to the back of the radio and the amp. Then you have to run the remote wire to the back of the radio and to the amp. On the speaker outlets you can either hook it up bridged or regular but bridged will get you more bass or power.
11/18/2008 12:59:08 AM • Rockford Fosgate... • Answered on Nov 18, 2008
2answers
Rockford Fosgate Punch P1000X5 5-channel car amplifier keeps blowing the in-line fuse?
Internal or external short. Disconnect everything but power, does it still blow? If it does, you need to take it in for repair..
4/20/2023 4:56:49 AM • Rockford Fosgate... • Answered on Apr 20, 2023
2answers
2 12 p3d212 2 ohm hooking up to a rockford
Hello a_brake11,
The P325.1 is relatively small to power a pair of P3's. You'll only get 325 watts RMS at 2 ohms (162.5 watts per sub). The P3's power range is from 100-500 watts, so they will work, but don't expect them to be really loud.
For best power, your subs should be wired with the voice coils in series and then the 2 subs paralleled to the amp resulting in a 2 ohm load.
Hope this helps.
1/4/2023 8:20:32 AM • Rockford Fosgate... • Answered on Jan 04, 2023
I have a Rockford Fosgate 1500 BD amplifier and terminals for the power cable will not loosen or tighten how do I fix it
First off will the fastener turn ? If not try using a bit of wd-40 and letting it "soak" for a little while . Also be sure you are using a good proper sized Phillips screwdriver . If the fastener still won't turn try using a can of "computer duster " inverted so the liquid comes out , note this will be well below zero degrees , and freeze the screw head , then try turning . If the fastener is stripped and the ttol slips you will have to remove the amp cover and grip it with a pair of vise grips ,pliers or a flat blade screw driver .
9/24/2019 1:31:53 AM • Rockford Fosgate... • Answered on Sep 24, 2019
My Rockford fosgate amp power light flashs red when volume is turned up
You may not have enough ground connection or your are running too much power for your amp
6/12/2019 8:53:47 PM • Rockford Fosgate... • Answered on Jun 12, 2019
2answers
Can I run 2 12 inch 2ohm fosgate and a 4 ohm 12 on a rockford fosgate 401s 1200 watt amp
Yes. Wire the two 2 Ohm speakers in series and connect them to one channel. Connect the 4 Ohm speaker into the other channel. This will give you a balanced 4 Ohm load on each channel.
5/12/2019 5:55:03 PM • Rockford Fosgate... • Answered on May 12, 2019
2answers
Rockford fosgate punch 45 hd mosfet wiring
i have a punch 45 but i'm missing the speaker wire connector.... were do i go to get one...
2/3/2019 9:15:30 PM • Rockford Fosgate... • Answered on Feb 03, 2019
Im looking for a wiring schematuc for the rockford fosgate Punch 40 slider can anyone gelp please?
Please be more specific. RF doesn’t share schematics
2/3/2019 8:58:29 PM • Rockford Fosgate... • Answered on Feb 03, 2019
I need the diagram for the Rockford Fosgate Punch 301m amp.
IF you are looking for a schematic diagram on the amp, you wont find it. IF you need the connection information you can look on their site, There is a repair video on that unit attached . Rockford Fosgate Car Stereo Amp Repair
1/13/2019 4:51:40 PM • Rockford Fosgate... • Answered on Jan 13, 2019
Rockford Fosgate Power 351M Car Audio Amplifier Logo
7 questions posted
Top Rockford Fosgate Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
John
John
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Rockford Fosgate Car Audio & Video
Most Popular Question
amp power wire going battery fuse
  • Car Audio & Video
