20 Most Recent
Rockford Fosgate Punch P4002 Car Audio Amplifier Questions & Answers
Rockford Fosgate P4002
Yes they are ! And that means the DC is on the speaker and will for sure damage the speaker if it already hasent
Any suggestions to get this transistor?
Um, hard to find eh ? Ok here are 2 links for those parts, in stock at mouser.
FQA 46N15:
http://www.mouser.com/search/ProductDetail.aspx?R=FQA46N15virtualkey51210000virtualkey512-FQA46N15
FQA 36P15:
http://www.mouser.com/search/ProductDetail.aspx?R=FQA36P15virtualkey51210000virtualkey512-FQA36P15
I didn't see any cross refs for that one. The only thing i didn't check was searching for other 150V N-Channel QFET, and 150V P-Channel QFET's, if you find some you could compare the datasheets. If you don't have time to lose, order from mouser :)
Cya ! cheebster.
2 12 p3d212 2 ohm hooking up to a rockford
Hello a_brake11,
The P325.1 is relatively small to power a pair of P3's. You'll only get 325 watts RMS at 2 ohms (162.5 watts per sub). The P3's power range is from 100-500 watts, so they will work, but don't expect them to be really loud.
For best power, your subs should be wired with the voice coils in series and then the 2 subs paralleled to the amp resulting in a 2 ohm load.
Hope this helps.
I have a Rockford Fosgate 1500 BD amplifier and terminals for the power cable will not loosen or tighten how do I fix it
First off will the fastener turn ? If not try using a bit of wd-40 and letting it "soak" for a little while . Also be sure you are using a good proper sized Phillips screwdriver . If the fastener still won't turn try using a can of "computer duster " inverted so the liquid comes out , note this will be well below zero degrees , and freeze the screw head , then try turning . If the fastener is stripped and the ttol slips you will have to remove the amp cover and grip it with a pair of vise grips ,pliers or a flat blade screw driver .
