20 Most Recent Mackie Onyx 1640i Mixer Questions & Answers
Mackie mixer will not work with windows 8
well depending upon the mixer and windows version you may have issues. Windows 8 is a 64bit platform, your mixer may only have 32bit drivers (x86). Try visiting the mackie forum for your mixer.
10/31/2017 2:24:09 PM • Mackie Onyx... • Answered on Oct 31, 2017
0answers
Helicopter sounds flashing
Sounds to have some bad capacitors. These are what they sound like when they go bad. They burst open allowing germanium to escape.
2/21/2013 11:46:54 AM • Mackie Onyx... • Answered on Feb 21, 2013
Hi. I have a Mackie
Check the settings in your computer in the control panel "sounds and devices" under the "Voice" and "Audio" tabs. Check that all are set to the Mackie instead of the computers default input.
6/10/2011 2:43:20 AM • Mackie Onyx... • Answered on Jun 10, 2011
I just got a mackie 1640i mixer yesterday. I
Likely you haven't got the levels set properly. Start with the trim controls (head end gain) Make sure you are not clipping there. Also verify you aren't overdriving your amps. Remember that the outs are line level, not mic level so the gain oof following equipment needs to be set for line level.
ALWAYS USE balanced audio line from this unit... either XLR or TRS type cables. ALWAYS power ALL interconnected equipment from teh same receptacle or source to avoid ground bounce damage to circuitry. You don't say what you are using to record with. Make sure it has balanced inputs. For instance, connecting cables from this to the audio input jack of a PC which is unbalanced would be a disaster in audio quality. There would be a problem of levels and the unbalanced thing... You haven't given us enough information of your hardware configuration to analyze the problem more than what I have said here.
12/26/2010 6:07:29 PM • Mackie Onyx... • Answered on Dec 26, 2010
Mackie 1400 SN:AH15857 Hot light on. Amp also works then goes quite then pops back on to normal.
Contact Mackie direct. They will know which component is failing. Link to the company for one of their powered speakers.
Thump215 15" 1400W Powered Loudspeaker
Mackie https://mackie.com > loudspeakers > thump-series-2022 The Mackie Thump215 15" 1400W Powered Loudspeaker brings the bass for DJs, venues, bands, and more and features a feedback eliminator and music ducking. //
1/20/2024 12:07:39 PM • Mackie Music • Answered on Jan 20, 2024
My aux 1 on my Mackie 1608 stopped working.Any ideas?
4/17/2023 4:15:13 PM • Mackie Music • Answered on Apr 17, 2023
My Mackie SR1530 is powering on but no sound.
If your Mackie SR1530 is powering on but you're not getting any sound, there could be a number of potential causes. Here are a few things you can try to troubleshoot the issue:
  1. Check your connections: Make sure that all cables are properly connected and securely plugged in. Check both the cables going into the speaker and the cables that are connected to your audio source.
  2. Check your audio source: Make sure that your audio source is turned on and properly connected. Try connecting a different audio source to the speaker to rule out issues with the source.
  3. Check the volume levels: Make sure that the volume on both your audio source and the speaker are turned up. Try turning up the volume to see if you can hear anything.
  4. Check the input settings: Make sure that the input settings on the speaker are correct. For example, if you are using an XLR cable, make sure that the input on the speaker is set to XLR.
  5. Test the speaker with a different audio source: If you have access to another audio source, try connecting it to the speaker to see if you can get any sound.
If none of these troubleshooting steps work, there may be an issue with the speaker itself. It may be a good idea to contact Mackie customer support or a qualified audio technician for further assistance.
2/25/2023 10:02:11 AM • Mackie Music • Answered on Feb 25, 2023
Mixer signals is on but qsc 1450 amp not giving any sound when main output is connected but when run aux send to amp it gives sound. What might be the problem.
If you are experiencing an issue where the QSC RMX 1450 amplifier is not giving any sound when connected to the main output of your Mackie 16 OK mixer, but works when connected to the aux send, here are some possible causes and solutions:
  1. Check the main output level on the Mackie mixer. If the level is too low or muted, this can cause the amplifier to not produce any sound. Increase the main output level on the mixer and check if the amplifier produces sound.
  2. Check the cables connecting the mixer to the amplifier. If the cables are damaged or not connected properly, this can cause the amplifier to not produce any sound. Ensure that the cables are connected securely and are not damaged or broken.
  3. Check the amplifier settings. Ensure that the amplifier is set to the correct input source and that the input gain level is set correctly. You may also want to check if there are any protection modes or limiters enabled on the amplifier.
  4. Check the speaker connections. If the speakers are not connected properly or are damaged, this can cause the amplifier to not produce any sound. Ensure that the speakers are connected correctly and are not damaged.
  5. If none of the above steps work, there may be an issue with the mixer or the amplifier. You may need to contact a qualified technician to further diagnose and repair the problem.
Remember to always follow the manufacturer's instructions and safety guidelines when working with audio equipmen
2/16/2023 9:15:52 PM • Mackie Music • Answered on Feb 16, 2023
Only one side of the mixer giving signals mackie cfx16 mixer
I would check the insert socket.
2/6/2023 7:38:19 AM • Mackie Music • Answered on Feb 06, 2023
I need diagram profx16 mackie for service .tank.
1/12/2023 3:47:55 AM • Mackie Music • Answered on Jan 12, 2023
Mackie CR1604 mixer hum on all channels
I doubt the issue will be the regulators if you have the correct voltage on them. Check where the hum is coming from. What frequency is the hum; 50/60HZ = mains hum = bad ground. 100/120HZ = power supply hum. Affected by a control somewhere maybe.
4/24/2022 7:16:15 AM • Mackie Music • Answered on Apr 24, 2022
Master volume not registering at correct level. Profx12
This unit will require an amp. I have set up several mixers and I do not watch output level numbers, you can get desired volume using amp. It does no good to drive input levels high output levels high and the turn down amp. Lower your inputs so no light flashes set master gain to -6 output and then raise amp volume. I have set up 16 mic mixer set individual levels and the feed to main mixer and controlled levels with one fader. I have taken mixes from main mixer to another mixer to control audio on video feed. A good band does not let member's set their levels . the audio person set levels, bad bands have members to set own level with resultant a mess that gets louder and produces sub par event. Remember good bands sound good and bad bands only sound louder, and bad
10/29/2021 6:53:16 PM • Mackie Music • Answered on Oct 29, 2021
2answers
Mackie 16.4.2.vlz pro. All the channel overload lights come on as soon as power is applied. Changing control/switch positions has no effect.
You probably have issues with caps in the power supply....I would check that first...open it up and look for buldging caps and replace any that you find....
9/27/2019 6:44:38 AM • Mackie Music • Answered on Sep 27, 2019
Mackie Onyx 1640i Mixer Logo
13 questions posted
Top Mackie Music Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Mackie Music Expert? Answer questions, earn points and help others
View Most Popular
Mackie Music
  • Mackie Music
Most Popular Question
helicopter sounds flashing
  • Music
