20 Most Recent Acer Aspire 5336-2283 Notebook Questions & Answers
5answers
I download a movie through torrent ,but it shows need of missing codec and ask me to visit http://bit.ly/getco...wat ineed to do now how can i get codec
my name is praneeth i'm to geting the same problem as small6363 so please... help send me instruction to my email [email protected] nor u can post it here hopeing that u r helping me byee
11/6/2019 9:12:35 AM • Acer Aspire... • Answered on Nov 06, 2019
Display screen not working
does it work with plugged into an external monitor?
7/28/2014 2:57:54 PM • Acer Aspire... • Answered on Jul 28, 2014
5336 as[ire when turn on screen is going to white comletely when screen movie up and down then iz working
This is actually pretty common and not really regarded as anything by the manufacture, if this ONLY happens for a brief moment during start up you're fine, typically a chip set update will solve this issue but it really isn't causing any harm so make sure you know which chip set you need. If it continues to happen for awhile even after boot up, re-seat your LCD cable (CAUTION! : making an error while doing this could cause you to break the LCD panel)
4/18/2013 4:10:26 PM • Acer Aspire... • Answered on Apr 18, 2013
Connection vga for bush led tv
Clarify your question? Are you going from your VGA out on your notebook and you want it to be plugged in to the HDMI input? you should have a vga input on your led TV. if you still want it to run on HDMI, then you need an adapter from VGA male to HDMI, you can find it on amazon.comTony Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
2/10/2013 8:42:32 AM • Acer Aspire... • Answered on Feb 10, 2013
How to video on remove 3v batt from aspire 5336
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Windows Advanced Options Menu Please select an option: Safe Mode Safe Mode with Networking Safe Mode with Command Prompt Enable Boot Logging Enable VGA mode Last Known Good Configuration (your most recent settings that worked) Directory Services Restore Mode (Windows domain controllers only) Debugging Mode Start Windows Normally Reboot Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select safe mode with command prompt Click start run type cmd press Enter black screen should open DOS mode this will vary depending on your operating system type in net user username For eg. If you want to change administrator password , type net user Administrator It will prompt you to enter the new password. Enter the new password and the password is changed if this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password Windows Password Recovery Basic http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
1/30/2013 8:45:54 AM • Acer Aspire... • Answered on Jan 30, 2013
Slow turn on notebook.. reinstall the os also.. i need help??
What do you need?
12/20/2012 11:37:45 AM • Acer Aspire... • Answered on Dec 20, 2012
Acer Aspire 5336 boot/screen/ram problem
Yeah, sounds like a ram problem. You can try re-seating it by pulling it out and putting it back in or its very possible the ram has gone bad and you will need to replace it.
10/24/2012 11:51:42 PM • Acer Aspire... • Answered on Oct 24, 2012
0answers
2answers
How to activate bluetooth in Acer Aspire 5336
Have you installed a Bluetooth driver for your specific laptop model? There should be a CD coming with your laptop that has all the drivers you need for it and probably for other models as well.. Also check if u even have a Bluetooth device built-in in your laptop. Turn-on your bluetooth icon, the installation process will start automatically, and after all click on "OK" button to finish all steps. When you are installing driver on your system, it may be possible that software ask you to activate bluetooth option, never close this window before OK.Feel free to get technical assistance at , if the same problem is still occurring....http://www.vtechsquad.com/acer-support/
9/12/2012 12:16:44 PM • Acer Aspire... • Answered on Sep 12, 2012
NO Bluetooth Devices
Have you used BT on this laptop before ? BT can be disabled/enabled in the BIOS, Windows, and often, depending on the Manufacturer, via the keyboard. ALL must be 'enabled' for it to work.
8/21/2012 9:40:38 PM • Acer Aspire... • Answered on Aug 21, 2012
2answers
When i charge my acer aspire the power button flashes
The DC jack in the laptop is showing early signs of intermittent issues, the jack is solded to the motherboard which sometimes breaks free over time, this is something that will eventually need to be addressed.
8/14/2012 5:58:40 AM • Acer Aspire... • Answered on Aug 14, 2012
I have problems with the ram in my laptop what can i do? how can i find out if its a hardware problem or software
To check if you have a RAM problem, go into the BIOS and check the amount of RAM installed, does this match the total amount of RAM installed, if the RAM in the BIOS does not match the total amount of RAM in the RAM modules then you may a faulty RAM module or an incompatible RAM module.If it is a software problem, a program may require more RAM than is installed on your computer. The software instructions will recommend the amount of RAM your computer should be installed with.
4/12/2012 8:24:29 AM • Acer Aspire... • Answered on Apr 12, 2012
Reinstalling windows os
Restoring your Acer back to factory setup will not bring back any viruses.BUT you need the Acer recovery CD for your model laptop.Acer Recovery CD is available from their WEB site.http://www.user-guides.co.uk/acer/acerrecovery/acer.asp?keywords=acer+aspire+5250+recovery&recor=1
2/25/2012 1:21:26 AM • Acer Aspire... • Answered on Feb 25, 2012
Have a laptop with no manual and can't get my wifi started.
go to Acer support then downloads follow the on screen prompts
2/11/2012 7:14:34 AM • Acer Aspire... • Answered on Feb 11, 2012
Im download movie from bit torrnet but movie not playng ask for missing codec how can i find out tthat's codec plz
You can download codecs for a variety of movie formats from here: Codecs or here: Codecs2
1/31/2012 1:34:31 PM • Acer Aspire... • Answered on Jan 31, 2012
Acer Aspire 5336-2283 Notebook Logo
54 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
5336 as ire when turn screen going white
  • Computers & Internet
