20 Most Recent Rockford Fosgate RFX-9200 CD Player Questions & Answers
How do i eject the cd
Press the open button at top left, if it fails to eject then you have it in auto -mode. make sure to press the open button for only a sec.
4/25/2013 6:33:09 AM • Rockford Fosgate... • Answered on Apr 25, 2013
I am having trouble with my display lighting.
To clarify, are you talking about your general dash lights, or a varying light level on the player?
If it's the dashboard lights, you could bypass the potentiomer by probably disconnecting one wire and joining it to the output. If the player display is controlled internally, in the player, you would have to open it and physically bypass the control circuit, but chances are that it's a ribbon connector inside the player, or possibly a bad solder connection that merely needs to be reflowed.
I would think your idea about rerouting the dimmer wire would work, though I've never tried it, or known anyone who has.
Wish I had a definitive answer, but hope this helps.
11/7/2010 1:58:08 PM • Rockford Fosgate... • Answered on Nov 07, 2010
How do I set the dials on the RFX 9200
www.rockfordfosgate.com/.../MAN3550B_RFX9100-9400_MAN.pdf
194.204.29.93/rockford/.../RFX9200/01_sourceunits_headunits_rfx-9200_manual.pdf
All in manual at links above.
4/7/2010 11:41:05 PM • Rockford Fosgate... • Answered on Apr 07, 2010
Fosgate rfx 9100 manual
just google it. you can easily find it online in pdf form just make sure you have a pdf viewer like adobe. best bet would be to find the company website and look for their manuals
3/17/2010 3:42:42 AM • Rockford Fosgate... • Answered on Mar 17, 2010
0answers
Mute
all you should have to do is turn the volume up
2/4/2009 2:38:44 PM • Rockford Fosgate... • Answered on Feb 04, 2009
Rfx9200
try to reset the unit... by pushing in the reset button under the faceplate... if that doesn't work call rf for technical support...
11/6/2008 8:56:43 AM • Rockford Fosgate... • Answered on Nov 06, 2008
Lost the manual and can't connect properly.
I have my sum hooked up to my sub woofer
11/18/2007 4:25:45 PM • Rockford Fosgate... • Answered on Nov 18, 2007
Rockford fosgate rfx-9200
If you're talking about the amplifier's power terminals, the positive terminal is designed to be wired directly to the battery (be sure to fuse the amp power wire near the battery terminal). The negative terminal should be bolted to vehicle chassis metal for a ground connection. The only amplifier connections that go to the back of the head unit are the remote turn-on wire and the RCA cables.
8/16/2007 8:31:14 PM • Rockford Fosgate... • Answered on Aug 16, 2007
2answers
Rockford Fosgate Punch P1000X5 5-channel car amplifier keeps blowing the in-line fuse?
Internal or external short. Disconnect everything but power, does it still blow? If it does, you need to take it in for repair..
4/20/2023 4:56:49 AM • Rockford Fosgate... • Answered on Apr 20, 2023
2answers
2 12 p3d212 2 ohm hooking up to a rockford
Hello a_brake11,
The P325.1 is relatively small to power a pair of P3's. You'll only get 325 watts RMS at 2 ohms (162.5 watts per sub). The P3's power range is from 100-500 watts, so they will work, but don't expect them to be really loud.
For best power, your subs should be wired with the voice coils in series and then the 2 subs paralleled to the amp resulting in a 2 ohm load.
Hope this helps.
1/4/2023 8:20:32 AM • Rockford Fosgate... • Answered on Jan 04, 2023
I have a Rockford Fosgate 1500 BD amplifier and terminals for the power cable will not loosen or tighten how do I fix it
First off will the fastener turn ? If not try using a bit of wd-40 and letting it "soak" for a little while . Also be sure you are using a good proper sized Phillips screwdriver . If the fastener still won't turn try using a can of "computer duster " inverted so the liquid comes out , note this will be well below zero degrees , and freeze the screw head , then try turning . If the fastener is stripped and the ttol slips you will have to remove the amp cover and grip it with a pair of vise grips ,pliers or a flat blade screw driver .
9/24/2019 1:31:53 AM • Rockford Fosgate... • Answered on Sep 24, 2019
My Rockford fosgate amp power light flashs red when volume is turned up
You may not have enough ground connection or your are running too much power for your amp
6/12/2019 8:53:47 PM • Rockford Fosgate... • Answered on Jun 12, 2019
2answers
Can I run 2 12 inch 2ohm fosgate and a 4 ohm 12 on a rockford fosgate 401s 1200 watt amp
Yes. Wire the two 2 Ohm speakers in series and connect them to one channel. Connect the 4 Ohm speaker into the other channel. This will give you a balanced 4 Ohm load on each channel.
5/12/2019 5:55:03 PM • Rockford Fosgate... • Answered on May 12, 2019
Rockford Fosgate RFX-9200 CD Player Logo
11 questions posted
Top Rockford Fosgate Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
John
John
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Rockford Fosgate Car Audio & Video
Most Popular Question
fosgate rfx 9100 manual
  • Car Audio & Video
