20 Most Recent
Chauvet 6x Chauvet Colorstrip Color Strip Led Dmx Proaudiostar Questions & Answers
I am using 3 Chauvet
Check if you may need to use a terminating resistor on the DMX chain. Sometimes digital reflections on the cable can cause random behavior.
Search "DMX termination" for explanation.
Also MAKE SURE you set the program mode to 021 (RGB).
It sounds like you might be in one of the automatic modes or sound triggered.
Peavey cs1000 x
The most likely case is that one of the main output transistors (if which there are many) is shorted. When the protect circuit senses DC on the final output, it will not allow the output relay to come on to protect the speakers from raw DC. With the power removed, you can check between each outputs Emitter and Collector and you will probably find close to zero ohms. From that point you need to unsolder each of the pins of the bad channel until you find the shorted device(s) and replace them.
2/7/2024 9:32:20 AM •
Music
Answered
on Feb 07, 2024
No or very little sound from Fender passport
Depending on the model, there are four around that date, it could be the insert jacks are tarnished reducing the signal flow between the pre amp stage and digital power amplifier. It could be the power amplifier has failed. It could even be customer error in wiring.
This assumes there is the correct level of signal entering the input sockets of course.
12/31/2023 8:25:12 AM •
Music
Answered
on Dec 31, 2023
