20 Most Recent
Korg Sound Card Disk O1w Fd 01wfd 01 W O1 O1w 01wfd Questions & Answers
My korg o1wfd needs a
This I am afraid is going to be a real problem. The original 01WFD's were shipped with the single density (720Kb) floppy drives, not the easier to find 1.44Mb ones. You could try contacting Korg.
From experience I can tell you that while many of the drives have similar interfaces, the music companies often had drives that required special strapping in regards to the drive select. There are not many of the single density ones around anymore... you might find one in a computer recycler's archives.
Trying to use the common double density 1.44Mb disks in the Korg is NOT going to work either, and if you have tried this, that MAY be why you are having problems, and new floppy drive isn't going to fix the problem... The "artifacts" left by 1,44 formatting remain between the tracks when put into the Korg.
To get around this, you can try TAPING over the extra hole that 1.44 disks have AND most importantly magnetically DEGAUSS the disk and then reformat using the drive in the Korg.
I have a disk not ready sign on screen, floppy
The floppy drives of this age often required strapping to select the unit number and other setups. Newer drives were not compatible. Make sure the drive selected light remains on when power is on. If not, check the drive selections jumpers for the drive.
