20 Most Recent Marshall Amplification Marshall AS50D Acoustic Guitar Amplifier (50 Watts, 2x8 in.) Questions & Answers
Marshall troubleshoot
First check the preamp valve in that curcuit
11/3/2021 6:47:15 AM • Marshall... • Answered on Nov 03, 2021
Can I use the speaker from the marshall mg30cfx with a marshall dsl15h?
Hi. Doesn't look like it as the speaker is a 4 ohm one and the head needs at least 8 ohm as far as I can see.
10/28/2021 5:24:26 PM • Marshall... • Answered on Oct 28, 2021
MARSHALL G15MS AMP OWNERS MANUAL
https://www.manualslib.com/manual/99237/Marshall-Amplification-Mg15msii.html
1/17/2019 10:35:23 AM • Marshall... • Answered on Jan 17, 2019
Marshall jcm2000 tsl combo turns on but no sound from any channel
Make sure speaker cable works and is connected then check fuses. If it has a master volume, make sure it's turned up.
1/8/2018 4:34:06 AM • Marshall... • Answered on Jan 08, 2018
Marshall valvestate 8080 experiences volume surges. Seems randoms as occasionally it won't happen or it will happen less than other times. But all the same annoying when playing! I get rid of i
Most likely cause for this is an intermittent potentiometer. Check to see if any of them are mechanically loose as this is a sign that they have been damaged and could have cracked the wiper surface inside the pot causing this problem. Alternatively, any switch that controls any gain setting could also be intermittent or dirty. Gain of the amplifier should be stable, but is controlled by the feedback and signal injection at the pots so that is where to look first. Good luck, as intermittent problems are tricky, but sometimes better than no function at all which can be more costly.
11/21/2017 6:23:21 AM • Marshall... • Answered on Nov 21, 2017
2answers
Electricity flowing. Why won't amp turn on?
What type of Marshall, please? First of all, control the fuse and let me know.
12/26/2015 6:04:44 PM • Marshall... • Answered on Dec 26, 2015
2answers
Marshall amp troubleshooting
Does anything happen while you turn the knobs on the amp? I had a similar problem with a yamaha amp. It turned out a couple of knobs went bad. Soldered new pots and it works fine for me now.
3/29/2015 11:37:19 PM • Marshall... • Answered on Mar 29, 2015
Can i connect 2 (2x12) cabs rated @ 4ohms each to my avt50 head?
No, the ATV50 head is rated for 4 ohms total. Using both 4 ohm cabinets at once will fry your amp. Your only option would be to rewire your cabs internally to 16 ohms each by connecting the speakers in parallel, but that would cut your amp's power in half.
1/25/2015 8:08:32 PM • Marshall... • Answered on Jan 25, 2015
1/25/2015 8:05:30 PM • Marshall... • Answered on Jan 25, 2015
0answers
Marshall Amplification Marshall AS50D Acoustic Guitar Amplifier (50 Watts, 2x8 in.) Logo
Popular Tags
1 questions posted
Top Marshall Amplification Music Experts
matt martin
matt martin
Ngoro
ADMIN Eric
ADMIN Eric
Are you a Marshall Amplification Music Expert? Answer questions, earn points and help others
View Most Popular
  • Marshall Amplification Music
Most Popular Question
marshall mg30fx loud tapping sound in
  • Music
