20 Most Recent
Naxa Electronics Nca-675 Questions & Answers
My naxa nca-675 was working
I would recommend disconnecting your battery and see if that helps. As far as the owner's manual, it is worthless by far. It does recommend however, to press the reset button but does not clearly specify how to accomplish that.
When i put on the
Mine is doing the exact same thing just bought it brand new a week ago I hope some one solve this
I i hook red to
Yellow is your constant +12 volt wire, and red is your switched +12 volt wire. It sounds like either your Red or Yellow wire isn't supplying the +12 volts it needs to. Only one of the wires is supplying voltage. You will need a multi-meter to check the voltage coming out of the Red and Ground, and the Yellow and Ground. The Yellow wire should have +12 volts at all times, even without the key. The Red wire should only have +12 volts with the key in the cylinder, and pointed to On. Find the wire that isn't supplying 12 volts, determine if it is switched, or constant, and then find a 12 volt wire that is switched or constant, depending on your findings. I’m happy to help further over the phone at
https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
