20 Most Recent
Motorola Mobility CITRUS Smartphone Questions & Answers
Cannot recive text messages,
check all your messaging this happens to me frequently. If your outbox has x amount and your inbox has an x amount as well as the draft folder it all adds up even tho logically it should be determined per folder. Empty the outbox first then your drafts that'll fixya right up
7/11/2013 9:22:54 AM •
Motorola...
Answered
on Jul 11, 2013
My motorola citrus doesnt charge all the way
It because if you looked where you charged your phone it might be dent you might off but your charger and click moving i know that because in my droid razer i did the same and know it wont charged that's why i using my motolora phone
1/19/2013 11:36:25 PM •
Motorola...
Answered
on Jan 19, 2013
Imei for citrus
The IMEI number is unique the each mobile/cell phone. The number is printed on the label under the battery. You can also get the IMEI number by entering this on your phone *#06# It will then display your IMEI number and you may also get a unique global serial number. Your IMEI number should be 15 digits.
1/3/2013 6:18:30 AM •
Motorola...
Answered
on Jan 03, 2013
My motorola citrus keeps resetting how can i fix this?
Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380# This function apparently works on almost all nokia mobile phones
12/31/2012 5:01:32 AM •
Motorola...
Answered
on Dec 31, 2012
My motorola citrus keeps resetting after a hard reset and wont stop ? what can i do to fix this?
It may happen that despite you have restored your mobile to factory setting, the error still exist. In this case, it is recommended that you opt for Hard reset •Enter the code: *#7370# and press Yes to confirm initialization. •Important Notice: It is recommended that you save all important information on your phone (e.g: memo, contacts etc) •To make a Hard Reset on a Nokia phone that is not willing to turn on, just press simultaneously these 3 buttons: •on/off + * + 3 •Before making a Hard reset better backup all your important information: contacts , memo...etc
12/31/2012 5:00:11 AM •
Motorola...
Answered
on Dec 31, 2012
Screen is black, cant get into menu.
This happened with my phone too. What I did was I reset the whole phone and there are different ways to go about doing that depending on the phone. You can usually get that information from your provider. Sorry I am unable to specify that information. Once you reset the phone you should be able to use it. If not I would contact your service provider for additional information and support. I hope this helps and good luck with your phone!
8/10/2012 10:40:34 AM •
Motorola...
Answered
on Aug 10, 2012
