20 Most Recent
Lenovo IdeaPad Z560 Laptop Questions & Answers
Funtional keys are not working in lenovo
Function keys on many laptops are used as the secondary set and the individual functions of the keys have been shifted to the primary functions. Thus, if you press F1 and things are normal, you would get some kind of "help" But if, as in many laptops, the functions of those "F" keys has been reversed you might get an Internet key, a brightness key, some kind of CD opening key, or whatever the manufacture decided. F2, as another instance, is used to trigger "edit" of the current item....but in many laptops pressing F2 just turns off your wireless signal or dims the screen slightly. In those cases the way to access the expected Fkey functions is to hole the Fn key down (at the bottom left of the keyboard) then press the desired F key. Personally I find it nuts to have reversed an PC age old way but I'm not in charge of keeping people happy so it's not happening.
Hope that helps.
My Lenovo Z560 laptop has
Welcome to FixYa
The softkey buttons on your system is controlled by the lenovo energy management driver software. Try reinstalling this. You can download it here
www.consumersupport.lenovo.com
Enter the serial number of your computer which is located on the bottom of the system. Look for the S/N number on a white sticker. Dowload and install lenovo energy management. Restart the system and check if that fixes the issue
Hope this helps
There is no os dvd with me now my os is corrupted
If you have a valid product key try here.
http://answers.microsoft.com/en-us/windows/forum/windows_7-windows_install/i-do-not-have-windows-7-media-but-i-do-have-my/5ce13741-ac25-4969-ae82-2494726aac1c
Format key
unfortunately this is a common problem for this device what you may want to do is call the manufacturer and notify them and they can normally send a restore disc for you as long as you have proof of purchase.
Lenovo z560 cpu overheating problem solved
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail. A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
I just bought my Lenovo
No worries, you should still be able to get onto your computer. It will just take a little elbow grease.
Alright, so the first thing you need to do is turn off your laptop and then the steps will follow as such:
1. Turn the power on your laptop on
2. Press the F8 key on your keyboard as your laptop starts up
3. You will notice a few choices available to you at the menu that will come up, choose safe-mode with networking.
4. Your screen will fill with all kinds of writing indicating that it is loading files. Don't panic, this is normal do no turn off the laptop.
5. It will bring you to the login screen of windows, here you will want to choose Administrator. No password should be required(if we got lucky with this)
6. Once windows has fully loaded, go ahead and click start, then control panel, then find user accounts and family safety.
7. once in here, there should be an option to edit your account. Go ahead and make the changes necessary to your password.
8. once this has been done and everything is has been applied, go ahead and restart your computer.
if you follow these instructions, you should be able to get your account back up and running no problem. i wish you the best of luck.
Lenovo i5 z560 methor bord
Hi hitesh,
I see you need a motherboard driver or what we term as a chipset driver.
See this
link to download the chipset driver for your system ....
once on the website select Download Drivers & Software, then Click the TAb Browse Product.
- Then on the drop down select Laptop and Notebooks then click continue
- Then select Ideapad Z series then click continue
- Then select Ideapad Z560 then click continue
- Then all Machine types will be highlighted just click on continue again
- Then select the version of windows that you have installed on you computer
- Once you have select the specific Windows on your system this will show you information of all the driver of your computer
I hope that this will help.
Have a nice day,
mvincentc
My lighting touch (mute key)
I suggest try to uninstall first the driver for the touch function see if the mute button light will disappear, if the light disappear it means its only the driver is having a problem and you can just reinstall back the driver for the touch function.
Hope it helps.
HOW TO EJECT A DISC IN LENOVO IDEAPAD 330
The CD/DVD drive may be opened by pressing a button on the drive itself. If the drive does not open by pressing a button on the drive itself, or the button is not available on the drive, Windows natively provides the ability to eject the tray with simple methods that can be performed in the File Explorer. The steps vary from different operating systems:
Note:
- Not all systems come with a CD-ROM, CD-RW, or DVD drive installed internally to the computer
- To verify that, you can check the left and right side of your machine. See if there is any slot to insert your CD/DVD. Normally, there is a button to eject the CD or DVD tray for you to insert a disc
- Another method to identify this is as below:
1. Click Start and type Device Manager in the search box. Select Device Manager
2. In Device Manager look for DVD/CD -ROM Drives
If you don"t see DVD/CD -ROM Drives this means your device has no optical drive hardware. An external optical drive will need to be purchased to run CD/DVD. It is also wise to check your product specification to see if your device has an optical drive.
If you were previously able to play CD/DVD and DVD/CD -ROM Drives has disappeared from device manager or your device is not reading the disc please follow > Your CD or DVD drive is not recognized by Windows or other programs.
- The format capabilities of the drive are listed on the label on the external cover of the drive
- The CD-ROM, CD-RW, or DVD drive can be opened using the emergency eject hole (Bend away a leg of a paperclip to work with. Insert the paperclip slowly until there is resistance, then gently push until the drive door is opened) Applicable Brands
Solution
·Windows 10
·Windows 7 Eject disk tray with File Explorer
- Turn off all applications currently using the drive. Otherwise Windows will prevent you from ejecting the DVD tray
- Hold Windows + E on the keyboard to open File Explorer
- Click the DVD drive icon and click the "Eject" button on the toolbar or right-click on the optical drive and choose Eject from the menu that pops up or down.
Win 10 lenvo ideapad 320 will not play mygames now
really why not ask the game maker directly for help with your w10.
here they are right>?
https://www.mygames.com/
so what do THEY say , it is there code, running.
does Tetris fail or just your games, unnamed,
this maker is bad company they take over your PC
why run this crappp? it takes over your browser,
and more,
and is bad.
the do not even have minimum system requirement there.
nor support. avoid like the Plague.
