20 Most Recent
Acer Aspire All-in-One Desktop PC - Silver (AZ3100-U3072) (2771498) Questions & Answers
How do I change the touch screen keyboard to a wireless
Your printer should connect up to any USB port (small rectangular opening near where the monitor and keyboard plug in (same type of opening). If your printer is so old it has a cream colored cable and one end that has 25 pins sticking out of it, you will save money by just buying a new $30 printer. Anyhow, newer printers connect with a thinner cable like your mouse cable, is flat / rectangular on one end, and is kind of tall-igloo shaped on the other end.
If you go for the new printer, I used to hate Epson, but bought one December 2013, and it uses a lot less ink than my older Canon or HP printer. I bought one with a touch screen panel and it can print from my smart phone and all the PCs without connecting any wires. The one I bought was about $100.
Your PC has a very new wired connection (Gigabit LAN) for your home network; but unfortunately does not come with a built in wireless card. If you are also unfamiliar with the LAN cable, it is an RJ45 connector. Looks just like a phone cable, but 50% wider.
If this is unclear, feel free to add more detail or let me know what you need more clarification on.
All the best to you,
Kerry
My recorded tv freezes when trying to watch them
The whole thing freezes? As in the mouse or keyboard won't even work?
If it's just the video that freezes and you can shut it off, most likely it's a codec issue. Which is dumb since everything you're using came packaged together in the unit. Installing a third party codec pack would solve this issue.
Though, if you're whole PC is freezing when you try to play a video then I have a few other questions to ask you to narrow the potential problems down:
1. Open up the player that opens automatically when you try to watch something, but don't load a video into it. Did everything still freeze?
2. If not, then open a video file that is not something you recorded from TV, like a DVD or a video clip from the net. Did it freeze then?
3. When it freezes, does it freeze instantly? Or does it run for a little bit then freeze. If the latter is the case, what happens in the time between opening the file and the lock down?
Computer has a blank screen and is beeping
sounds like possible RAM problem issue. If you are able to get to the RAM on your PC i would recommend removing one of the modules to see if it will boot, if not then try just the module that you removed previously. (this is dependent on the PC having two modules to start with)
Acer wireless keyboard
Click start control panel keyboard hardware make sure you have the right
keyboard selected
or you might have uninstall the keyboard then restart your computer then
reinstall it and its drivers
Click start control panel administrative tools computer management device
manager scroll to keyboard you might see a yellow question
/exclamation mark ? ! or a red X right click update driver
if your computer came with a motherboard disk the drivers could be on it.
Rather doing a driver hunt
which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
it might take some time being a freeware driver solution
Note: it will find all of your outdated drivers
You will have to update every driver individually once you
update you might be asked whether you want to restart or make a system restore
point.
Click no to both of these then continue updating
each driver free then restart once all of the drivers have been updated.
How to install a new harddrive in an acer 23" all-in-one?
If you replace the HDD you will have to do a reinstall of Windows or clone the drive. If you have the Factory Revovery DVD's then you can reinstall to Original Factory Condition. All you data will be lost. If you clone the drive, it will be as it was when you removed it. That said, is there a problem with the HDD? Why are you replacing It? The HDD hardware replace is the easy part.
