20 Most Recent
Nintendo Dsi XL Questions & Answers
Error code 051112-1
is your wifi password the same as at home because if it isn't you need to have a whole different one one that is on the wifi modem or router at grandmother's house
Up date nintendo dsi xl
Hi there!
To update your DSi XL you will first need to make sure your DSi is connected to the internet. If your DSi is not connected to the internet, do this follow the steps in this link:
How to Connect to the Internet Nintendo Support
Once your system is connected you will need to select the system settings icon (the wrench) from your DSi menu, click the right arrow 3 times and click on "system update." Then click "yes," then "next,"then "I agree," then "ok" to start the update!
Have a fantastic day!
Error code:369014
Sign in to your Facebook through your computer first to ensure it works.
While online on your computer, go to the login screen of Facebook on
your DSi/XL and check the box that says "keep me logged on" or "keep me
signed in". Then sign in through your DSi/XL, exit the browser and
return to the menu, then go back to the photo channel and try again.
I have a nintendo dsi
Water damage usually spells the end for any gadget, but you can try the following and see if it helps.
Put the DSi into a warm, dry place (usually a hot press or something similar). Make sure it is not too hot as you will just burn out the DSi. Place a bowl of plain white rice beside the DSi and leave for 12 hours. Repeat with a fresh bowl of rice for another 12 hours if the problem persists.
Please bear in mind that the rice is there to soak up any water vapor in the air, it's not going to magically fix your DS but it is a tried and tested way to dry out gadgets of this kind.
Best of luck!
I have bought a dsi
if you tried to turn it on while it was still damp it could have damaged the electronics srry
