20 Most Recent
PQI H551 500GB 2.5" USB 2.0 Portable External, Blue - 6551-500GR100A Hard Drive Questions & Answers
I can't open my HDD551,
Hi. first you have to figure out if the problem is with the HDD or with your computer, to do this connect your HDD to another computer and see if you can open the information, if the problem is the HDD take it to a service center, if the problem is your computer re install the drivers for the HDD.
Good luck.
Why my hardisk drive cant detect in pc,thx for
It could be one of the following
1. Faulty USB port on PC: Try a different computer or laptop
2. Faulty USB cable: Try a different Cable
3. Corrupt memory: Fix by an expert required such as www.SaveMyUSB.com
4. Faulty connections on main circuit inside the hard drive: Fix by an expert required such as www.SaveMyUSB.com
5. Faulty controller chip (worst case senario) : Direct flash memory read required by an expert required such as www.SaveMyUSB.com
Hope this helps and that it is 1 or 2 as 3, 4 and 5 will cost you money.
Good luck,
Martin.
Driver memory stick
W 7
First, please disconnect all USB devices and then
perform the following steps:
Click "Start" button, type "devmgmt.msc"
(without quotation marks) in the "Search" bar and press "Enter".
Click "Continue" if necessary.
In Device Manager, double click to expand
"Universal Serial Bus controllers", right click on the Host
Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under
"Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will
reinstall all USB controllers automatically.
for XP or earlier
Click start right click on computer select
properties device manager scroll down universal serial bus controllers
you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers right click
to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this
fails to fix the problem
Check the USB leads that attach to the motherboard
usually red white green black make sure they are securely seated and have no
dust build up on them dust will cause static and a lot of unforeseen problems
to a computer and its parts
if you need more help with
this or if i have missed the problem post a reply
My Computer suddenly does not
Check the following
- With the drive plugged in on powered on place your hand on it should be able to feel it vibrating (if no its not getting power or dead)
- If power and vibrating put your ear to the drive (repeating and squealing are bad, crunching sound is generally ok)
- With the drive plugged in and it sounds ok and it's vibrating[platters are spinning] right click on "Computer"/"My Computer" select manage > Disk Management, locate your drive if it is listed try to initialize it
- Right Click drive, properties, hardware tab, select drive, properties, volume tab and click populate
If it wont populate or doesn't show at all in storage manager at all either the drive itself is bad or the control in the external enclosure is bad. You can attempt to remove the drive from the enclosure and plug it in directly into the computer but this tends to void it's warranty. If the drive works however you can simply buy a new enclosure for about $12
Comment back if you need more assistance
How to Install YouTube DL.py to Download YouTube Videos to my PC?
Actually, you just need the help of a YouTube Downloader. If you still need help, why not try this YouTube/Video Downloader?
Leawo YouTube Downloader acts far more than a single online video downloader to download YouTube videos and other online videos from various video sharing sites like Facebook, Dailymotion, AOL, iFilm, Myspace, Dailymotion, etc. Besides the ability to download online flash videos, this FLV downloader could also acts as video download accelerator to speed up online video downloading, video accelerator to speed up video buffering for smooth playback, video player to play back videos, and IE browser to browse online videos for free downloading. It could extract audios out of online videos, like converting YouTube video to MP3.
Hope it can be another choice for you or other users. :)
Watch online videos offline freely with Leawo YouTube Downloader
What is digital marketing?
Digital marketing, or “online marketing,” is a form of advertising that uses the internet and digital technologies to connect with customers. Digital marketing seeks to accomplish the same thing as traditional marketing except by leveraging computers, smartphones, and other digital devices rather than traditional media, such as print, radio, or television.
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
