20 Most Recent
Sony RM-VZ320 Remote Control Questions & Answers
RM-VZ320 won't even turn on my player, help?
depending on age you might have to take apart not hard and clean the key pad where they make contack with bard with pencial erraasor or rubbing alcohol and a cotton swab to clean contacts good luck
Maganvox product codes
There is no setup codes for Magnavox with this Sony RM-VZ320. . For more information check this link. Setup procedure, and setup
code list to many popular remote controls are given. Pull up older posts. . If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device
Sony universal remote won't control the volume
http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMVZ320
Try the above Sony web site, where they have support, or call a Sony Dealer.
http://store.sony.com/-cms-page.sony.authorized.dealer.list?XID=M:accessories:esupport
Programming instructions for a sony rm-vz320 to program a JVC TV
Programming instructions are too much to type in here. If you wish to get more details, check
this site.
Pull up previous posts there. Setup code list and setup proceedings to
many popular brand remote controls are given.
Three digit, four digit, five digits and two-digit code list are
there. Check the site with
patience. Surely you'll get a solution
to your problem. Search the site by
'Timeslide' option. It will make search
easy. Or, type in the brand name to
your device into its search box, and press "Enter"Check
this site too.
