20 Most Recent
Velocity Micro Cruz Reader R101 Tablet PC Questions & Answers
How can I sync my
I have a cruz t301 woould like to know how to sync my tablet with my pc.I have trided the aacount will not work says can not connect to server.Would like to do this so i can use it for my school on line work.Would like your help thank you.
Will not connect to my
i cant connect to the wifi i have a rooter on my android acend it connect to my labtop but my cruz reader wont even make the wifi pop up its not found
Forgotten pattern to unlock
try 4-5 times continuously after that it would ask you the security answer, filled at the time of applying pattern lock.
Want hook to internet
From the home screen ,select the shortcut icon that reads wifi settings and ensure that both wifi and network notification are enabled with green checkmarks..After a moment,your wifi networks list should populate.If you need to rescan for available networks,tap menu,then tap scan.Detected networks will appear.Those that are secure will feature a padlock,and open will have no padlock.Tap the network you wish to connect to and then click connect.If a passwrd is required,tap the text field for the popup keyboard..Once the cruz has successfully connected to any network,it is saved.
Forgot password for tablet
Reset windows password not a problem any more nowadys. The easiest way to reset a forgotten Windows password I ever use is to use
Windows Password Reset ,just a few steps:Step 1: Download and install Windows Password ResetStep 2: Burn Windows Password Reset Std ISO file to CD/DVDStep 3: Put in your newly created CD and remove your Windows Password.Hope it can help you
Tesoar tablet freezing on tesoar screen
Try this:
First, turn your tablet off. Then, power the tablet back up by holding down the volume (either + or - ) and power buttons simultaneously. Continue holding the volume button until the screen says "Booting tablet in recovery mode." This will give you a picture of an Android. Tap the android, and you will be given a screen with several options. Move between the options with the + and -, and select with the power button. Go to the option for Factory Data Reset and select it. Scroll down to `the Yes, and then the tablet will erase its memory back to factory settings. Once it has completed, select Reboot Tablet Normally.
