20 Most Recent Rockford Fosgate FAPT1 5.1 Channels Receiver Questions & Answers
Subwoofer distortion with low volume
We need to know what the amp is and its model, what the speakers are, what the enclosure is.
1/18/2018 12:35:08 AM • Rockford Fosgate... • Answered on Jan 18, 2018
Amp isn't working but its
Hi tazmattiejoe,
  • The problem could be with the fuse , check if the fuse is proper and not blown up , if it's burnt then all you need to do is replace the fuse.
  • If it's not burnt up then you need to check the input device for the amp and if you can see power being reflected on the amp and it's properly switched on.
  • If the amp appears to be powered on but not working then you need to check if it's giving you an out put by changing the speakers , usually the input is the problem , when there is no input in the AMP or there is a mistake in connecting the input to the AMP there would be no output which could make us think that we have the problem in the AMP itself.
Therefore please check the inputs and out puts of the AMP and your CD/DVD player devices.
Hope that helps ...:) Let me know in case you require any further assistance , your feedback would be appreciated.
9/12/2011 8:18:32 AM • Rockford Fosgate... • Answered on Sep 12, 2011
I dont know the wattage of my amps, can anyone help?
Specs are here:http://www.hertzaudiovideo.com/Doc/S...nica_space.pdf
Basically this is a 6.5" mid (7" outer diameter including the ring for the grill) with a front-mount neo motor, composite basket, and a water-resistant paper cone. Mounting depth is 1.5". It's rated at 100w RMS and 200W max.
4/20/2010 11:24:46 PM • Rockford Fosgate... • Answered on Apr 20, 2010
How to bridge a punch 3001 car amp
You can't bridge this amp as it is a mono single channel amp. 2 ohms is the lowest load that can be applied for 300WRMS.
2/26/2009 5:17:23 AM • Rockford Fosgate... • Answered on Feb 26, 2009
My rockford fosgate amplifier P500
Check your amps ground and make sure it has a clean connection to the chasis. If there is paint or any kind of coating where you are trying to ground, use a steel brush to expose the bare metal. Also, make sure you are grounding the amp directly to the chasis and not to another grounded wire.
Hope that helps.
9/22/2008 9:09:18 PM • Rockford Fosgate... • Answered on Sep 22, 2008
How to install Rockford Fosgate
You will need a line level adaptor to get an audio input for the amp.
A line level adaptor is a device that lets you tap off of your speaker outputs of the radio and it converts that signal into the proper level for an RCA input signal the amplifier uses.
If you are installing the amp in the trunk of the car you can just tap off the speaker outputs of the rear speakers mounted in the trunk. Keep the speaker outputs connected to the speakers, just run an extra set of wires from them to the line level adaptor. It will not take anything away from the speakers sound because it is not a power drain on them.
After that, you just connect the power wires for the amp as you would normally and you also need to run an extra wire from the radio power antenna wire to the remote turn on of the amp, or you can use a wire directly from the battery and connect it thru a switch you would need to connect somewhere around the dash, so you can turn the amp on and off when you need to. The power antenna wire from the radio is best, so you don't need to turn the amp on and off manually. It is easy to forget about turning it off sometimes and that would run doen your battery if the amp is left on over night even with no signal going thru it.
Then connect your speakers to the amp and thats it.
Then big issue is getting an audio signal to the amp and the turn on signal for the amp.
If you need more help let me know,
Dave
8/8/2008 12:16:38 PM • Rockford Fosgate... • Answered on Aug 08, 2008
Vocalizer 3 output checked cables and swapped out. 1300 watt power adaptor lights up. sound indicator light is on but no sound. tried mono and stereo. power adaptor problem?
If the display is working, you have audio. Check your amplifier. 1300Watt adaptor ... This unit draws a very low power and that is not needed.
4/24/2024 7:18:55 AM • Audio Players &... • Answered Yesterday
How do I change to degree mode on my porpo YH-2000
  1. Power Off: Turn off the device.
  2. Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
  3. Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
  4. Power Off Again: Turn off the device once more.
  5. Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
  6. Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
4/20/2024 8:57:52 PM • Audio Players &... • Answered on Apr 20, 2024
Panasonic SA-PM250 CD stereo system. Tune dab radio sa pm250?
this model SA rather than SC seems to be a Middle East model. The SC version doesn't have DAB. https://www.google.com/search?q=panasonic+sa-pm250+instruction+manual ..
4/20/2024 5:59:04 PM • Audio Players &... • Answered on Apr 20, 2024
Setting time on fmdott085 V398
All questions need clear 'make model (what it is)' first 3 words. https://www.google.com/search?q=fmdott085+V398 ..
4/17/2024 4:54:26 PM • Audio Players &... • Answered on Apr 17, 2024
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS. Question moved from Cars and Trucks category. Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries. How long is the warranty on AfterShokz? While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase. Jan 11, 2019
How To File A Warranty Claim For Your SHOKZ Headphones
https://www.google.com/search?q=Openfit+Shokz+battery+replacement ..
4/16/2024 4:58:24 PM • Audio Players &... • Answered on Apr 16, 2024
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first. But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
4/16/2024 5:57:29 AM • Audio Players &... • Answered on Apr 16, 2024
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
4/10/2024 6:11:44 AM • Audio Players &... • Answered on Apr 10, 2024
Zenith Allegro console stylus
I have the same model with the 8 track player, original manual, and original receipt dated 1975.
4/9/2024 1:32:47 PM • Audio Players &... • Answered on Apr 09, 2024
Rockford Fosgate FAPT1 5.1 Channels Receiver Logo
0 questions posted
Top Rockford Fosgate Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Eric
ADMIN Eric
Are you a Rockford Fosgate Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Rockford Fosgate Audio Players & Recorders
Most Popular Question
subwoofer distortion low volume
  • Audio Players & Recorders
