20 Most Recent
Samsung HT-C6500 Theater System Questions & Answers
I cannot get the wireless
That can not be decided so easily. It could be your receivers USB port is fried as well. I would suggest taking it to an electronics repair shop, but ask for free testing of both just to be sure of what you are dealing with.
If you happen to still be within warranty with samsung, it would be a good idea to call them to see your options, as long as there has been no water damage or other, they should be able to point you in a clear direction.
I seriously doubt posting here will lead to much if its not even recognizing the dongle.
Sorry I don't have a clear solution for you, but I hope you can get in touch with the right people to get it working for you.
Cheers.
I CANNOT GET THE WIRELESS REAR SPEAKERS TO WORK.
I just fixed this problem with my theatre system. First, if you use speaker wire and not plugs, pull out, than reinsert the wiring, sometime it doesn't properly connect. Make sure that your sound field is turned to Surround Sound. Funnily enough, these are the two most common issues.
Then check rear speaker volume. If there is a switch or button to choose A, B or A+B speakers, attempt adjusting this.
That should do it. Even if you're not playing surround enabled content, but to be safe, ensure you are.
Cant fnd tx card
Hello, encompass parts .com is an authorized samsung parts distributer that will sell to the public.
I cant get my comcast
You can get The comcast remote to control the volume on the Samsung HT-C6500 TS by turning ON the Anynet feature on the HT.
Try this
link and download the instructions manual for the comcast remote.
Hi, I'm using the Samsung HT-E330K. It works but does not speak out. The power display is fine but no sound
If your Samsung HT-E330K home theater system is not producing any sound even though the power display seems to be working fine, there are several potential causes and troubleshooting steps you can try:
1. **Check Volume Levels:** Make sure the volume on the home theater system and the connected TV (if applicable) is turned up and not muted.
2. **Check Audio Source:** Verify that the correct audio source is selected on the home theater system. If you're using multiple input sources (DVD, TV, AUX, etc.), make sure the right input source is selected.
3. **Audio Cables:** Ensure that all audio cables are securely connected to both the home theater system and the audio source (TV, DVD player, etc.). Sometimes, loose or faulty cables can result in no sound.
4. **Speaker Connections:** Check that all speakers are properly connected to the home theater system and that the speaker wires are securely inserted into the appropriate terminals.
5. **Audio Settings:** Go through the audio settings on both the home theater system and the connected TV (if applicable). Ensure that the correct audio output settings are configured.
6. **Mute Function:** Double-check that the mute function on the remote control or the home theater system itself is not engaged.
7. **Speaker Balance:** Check the speaker balance settings to ensure that sound is not unintentionally directed to one side or speaker.
8. **Reset to Default Settings:** If you've made any changes to the settings recently, consider performing a factory reset to revert to the default settings.
9. **Firmware Update:** If there is a firmware update available for your home theater system, consider updating the firmware as it might resolve any software-related issues.
10. **Test with Different Source:** Test the home theater system with different audio sources to rule out issues with a particular device.
11. **Test Speakers:** If possible, disconnect each speaker one at a time and test the audio to identify if a particular speaker or speaker wire is causing the issue.
12. **Check Speaker Impedance:** Ensure that the speakers' impedance matches the specifications of the home theater system. Mismatched impedance can affect sound quality.
13. **Contact Support:** If you've tried these steps and still have no sound, consider contacting Samsung customer support or seeking assistance from a professional technician for further troubleshooting and repair.
Remember to refer to your device's user manual for specific instructions related to your model.
