20 Most Recent
Nyko Wand? for Nintendo Wii Questions & Answers
My wii remote just stopped
Try removing the batteries after you turn off the system. This will turn off the power to your Wii Remote. Once it's off, put the batteries back in and turn on your Wii. If nothing happens on the Wii Remote, then it needs new batteries.
If you're still getting weird errors, push and hold the power button on your Wii for ten seconds. If you have problems after doing this, contact Nintendo at 1-800-255-3700.
Wii nyko remote not compatible with just dance 2014
I have the same problem. It is not a sync issue. Can turn on wii console with Nyko controller, then go into Just Dance 2014. About 4 seconds later the Nyko behaves very strangely, makes some noises and turns off. Controller that comes with the Wii is fine, only the Nyko has problems, and only with Just Dance 2014. JD 2013 and all other games we have are perfectly fine.
I have exactly the same
1) Open the battery compartment and there should be a small circular red button.
2) Next to the Wii's SD storage area there is a rectangular square button.
3) Hold down the red button on the controller and the red button on the Wii until the light on the controller stops blinking.
Sometimes it can take multiple tries to "sync" the controller with the Wii. Keep trying until the lights stop blinking.
I have 2 nyko wands
ok you will need to synchronization.Press the power button on the wii conosle to turn it on remove the battery cover on the backof the remote.Press and release the SYNC. button inside the cover.the player leds will blink.Open the fornt door on the wii console press and release the SYNC.button on the inside of the compartment. when the player LED blinking stop connection is complete the LED that is iluminated indicates the player number, THAT IS IT
I have one nyko wand and one wii want for my new
On the Wii menu, if you press home button, and click "Wii Remote Settings" then "Reconnect" it will enable you to connect wiimotes by pressing 1 and 2 simultaneously. Also some games, Wii sports for example, allow you to use one controller for two or more people.
All four lights on bottom blinking
you have to sync the remote with the wii to be able to use is.
procedure should be the same as for the original wiimote
Standard Mode SynchronizationNote: Make sure you have placed batteries in the Wii Remote (
how to).
- Press the Power button on the Wii console to turn it on.
- Open the SD Card Slot cover on the front of the Wii console.
Remove the battery cover on the back of the Wii Remote you
wish to sync up.
- Press and release the SYNC button just below the batteries on
the Wii Remote; the Player LED will blink. Quickly press and release
the SYNC button on the inside of the SD Card compartment on the console.
- When the Player LED blinking stops, the syncing is complete. The LED that
is illuminated indicates the player number (1 through 4).
This procedure must be followed for each additional Wii Remote added
to your system
