20 Most Recent Magnavox 26MD350B/F7 26 in. LCD TV/DVD Combo Questions & Answers
check mute on remote control unit
Magnavox... | Answered on Feb 23, 2016
go e-bay and in the search box type in-- audio speakers
Magnavox... | Answered on Oct 19, 2015
Fault to the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Magnavox... | Answered on Sep 13, 2015
YOU PUT TV IN DEMO MODE, HOLD VOLUME UP AND CH. UP AT SAME TIME PLUG TV IN WHILE HOLDING ALSO POWER BUTTON FOR 15 SECONDS. SHOULD CLEAR.
Magnavox... | Answered on Oct 31, 2014
Make sure the proper input on the tv is selected to match where the cables are plugged in.
Magnavox... | Answered on Nov 18, 2013
pushing the play button should do it
Magnavox... | Answered on Mar 21, 2013
download from web sight.
Magnavox... | Answered 2 days ago
Hello Steve, for what you describe, your Magnavox TV has power problems
Discuss the model of your Magnavox
You can try plugging it into another power outlet, if you have power cord, interlook type, you can change it
If with all these tests, you have no result, the problem is inside the television, probably in the power supply
If you have technical knowledge, I suggest you remove the back cover and locate the power supply and check if the fuse is burned, if so, replace it with an equal one, no more small, or larger in its current capacity, to avoid major problems
If the fuse is bad, replace it, if it burns again, this definitely indicates that the problem is in the power supply
In this case, contact a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Steve, por lo que describes, tu televisor Magnavox, tiene problemas de alimentaci?n de energ?a
Comenta el modelo de tu Magnavox
Puedes probar conectarlo en otro toma corriente, si tiene cable de corriente, tipo interlook, puedes cambiarlo
Si con todas estas pruebas, no tienes resultado, el problema esta dentro del televisor, seguramente en la fuente de alimentaci?n
Si tienes conocimientos t?cnicos, te sugiero que le saques la tapa posterior y ubiques la fuente de alimentaci?n y revises si el fusible esta quemado, si es as?, reemplazalo por uno igual, ni mas chico, ni mas grande en su capacidad de corriente, para evitar problemas mayores
Si esta mal el fusible, lo reemplazas, si se vuelve a quemar, esto indica definitivamente que el problema se encuentra en la fuente de alimentaci?n
En este caso, ac?rcate a un servicio t?cnico especializado
Espero puedas resolver el problema
Saludos Franco Dosil
Magnavox... | Answered on May 12, 2019
Magnavox 26MD350B/F7 26 in. LCD TV/DVD Combo Logo
18 questions posted
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Magnavox Televison & Video
Most Popular Question
yo find speakers online
  • Televison & Video
