20 Most Recent
LaCie 500GB Rikiki USB 3.0 Portable Hard Drive Questions & Answers
LaCie Rikiki stops working. The led does not blink.
This kind of fault is usually the case to drive interface. You can remove the drive and try to plug it into you computer using the IDE or SATA cables your drive needs. You will then be able to tell if it is your drive or the case.
Formatteren
New drives have to be readied for use. Try Start > Run (aka Search in Win 7) type dskmgmt.msc. Look for your drive there. It should be without a drive letter. Right clicking will give you the options of initializing, creating disc partitions, assigning logical drives, formatting. If this seems a little daunting. A wizard should load. If not there is refresh icon on the tool bar.
Usb cable is causing a short circuit
the first cable (throw it away), the secound use that one or a new one. then you will need to locate the drivers on the internet, download them and install.
My hard drive is not being detected by my
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red xright click to reinstall drivers or if you can see your usb but its not workingports(com&lpt)right click update driver sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seatedif this fails to fix the problem you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap hope this helps
My computer says la cie external hard drive is
You can try a program like http://www.piriform.com/recuva
But if your hard drive is damaged you will need data recovery help. This guy does it remotely and just works for donations http://FreeDataRecovery.us
I want to use my hard drive on a pc. I have only
there are a few ways to make your drive work on a PC.
First, if you do not need the data on the drive, you can go to Disk management in Windows and format it. To access Disk Management, right click on My Computer on the desktop, then select Manage and Disk Management will be in the list there.
If you need the Data, you will need to purchase a software like MacDrive which allows a Mac formatted drive to be accessible on a PC.
Regards,
LaCie 500GB portable hard drive is giving error
The symptoms indicate there is a problem with the drive, how it is
connected, or with the computer used for troubleshooting. The next best
step is to change physical variables, and find a simpler problem than a
broken product.
- Change the data cable (USB, FireWire, Ethernet, etc.) A failure in the cable can cause this issue.
- Change the external power supply or cable. If a different LaCie
product is available, borrow the power cabling from that unit to see if
the problem is in that component. On drives that are powered via USB or
Firewire, try using the included power sharing cable and connect it to a
second port.
- Change the computer you are using. Computer problems can manifest
themselves in many ways. Even if the computer appears to be working
properly, this is a worthwhile test.
Then run
