20 Most Recent
Ragalta RWC-100 White Countertop Thermo Electric Water Cooler with Co Questions & Answers
My hamilton beach Top cooling Water Dispenser Model Number Tl-1-2 is not cooling water a few hours ago The motor is constantly working,however, the blue light not switched off Please advise
A few troubleshooting steps you could try:
Check the Power: Ensure that the unit is properly plugged in and the circuit breaker hasn't tripped.
Check the Cold Switch: There should be a cold switch on the back of the unit. Make sure it's in the ON position.
Temperature Limiter: It's possible that the temperature limiter may have tripped. You can try setting the hot and cold power switches to the OFF position, wait five minutes, then set the switches to the ON position. Wait 30 minutes for the water to heat or cool.
Mineral Build-up: If the dispenser has been used for a long time, there might be a mineral build-up in the tank that could be clogging it3. You might need to clean the dispenser to remove these deposits.
If none of these steps work, it might be best to contact Hamilton Beach customer service for further assistance
Viva bottom loading water cooler does not dispense water
Some others addressed this issue on Fixya.com before:
Brett 42 said: the water line is froze.. I took a hair dryer and applied it directly to the dispenser for about 10 minutes. I then held down the buttton for approximately 30 seconds and the water began to drip extremely slowly then faster until a small chunk of ice shot out of the dispenser. I believe the reason this happened was that I the temp of my freezer set lower than the fatory setting.
Mike Smith said: "1) remove the tubing connector behind refrig kickplate . Press for water . If no water comes from tube under refrig , then possibly frozen tank but probably not . Probably bad water inlet valve . ( tank is in the lower potrion of the refrig section behind the crispers ) .
2) if water does shoot out , then your freezer door is frozen which requires leaving door open and tapeing light switch closed and tape plastic around freezer section opening so fridge will continue to operate normally . Thawing freezer door could take a day or 2 . 3) You can plug the hoses back togather and walk by occasionally pressing water untill comes out . Lower your freezer temperature setting also ( could be set for too cold)"
I hope this helps you out!
